C5 codes
Old Aug 6, 2022 | 06:37 PM
Dontblink7's Avatar
Dontblink7
6th Gear
Default C5 codes
Hello. I have a 2000 Corvette and I am getting a service vehicle soon message in the display.
I scanned it and have two codes:
- C1255 ebcm internal malfunction
- C1281 vses sensors uncorrelated
does anyone know what the fix is on these?
thanks guys
Old Aug 7, 2022 | 09:11 AM
grinder11's Avatar
grinder11
Oh NO!!! IIRC, the C1255 is the kiss of death for the EBCM. I may be wrong, but I dont think so. If I am, someone will be here-SOON-to correct me!!!
Old Aug 7, 2022 | 09:19 AM
runner140*'s Avatar
runner140*
You are not wrong....
Old Aug 7, 2022 | 11:20 AM
Dontblink7's Avatar
Dontblink7
6th Gear
kiss of death? Meaning what? No fix? Or that it needs to be replaced? Any insight on the other code? Thank you
Old Aug 7, 2022 | 03:25 PM
grinder11's Avatar
grinder11
Correct. It can't be fixed, and will need a $900.00, give or take) USED part to replace it. No new SWPS, or EBCMs are available, and this is why many favor the '01-'04 models over the '97-'00 models. FYI, I dont think either parts are available new for the '01-'04 models, either. BUT....The EBCM can repaired on the newer ones. I have a 2000 C5 Vert. As for the C1281, I believe that this code indicates an issue with the SWPS, IIRC.....
Old Aug 7, 2022 | 03:44 PM
Smoken1's Avatar
Smoken1
I think I would look into what is causing the C1281 code first. Have you done any work to the car such as add headers or something that would require disconnecting your steering?
Old Aug 7, 2022 | 04:31 PM
rrwirsi's Avatar
rrwirsi
This is why I will never buy another GM Car. The EBCM is an important part in the high profile Corvette line and not to have a replacement option either by the original manufactyurer or by giving licensing to an after marker is just dispicablke.
Old Aug 7, 2022 | 08:54 PM
Ciro's C5's Avatar
Ciro's C5
Does the C1255 ebcm internal malfunction mean that the car is no longer drivable? Can it be by passed? It's crazy that this can cause something as serious as everyone states.
Old Aug 7, 2022 | 09:05 PM
Dontblink7's Avatar
Dontblink7
6th Gear
Do you know if the ebcm has to be programmed by a dealer once installed? Also, I should note that the vehicle drives perfect with no issues other than the message that comes up on the dic.
also, any other insight on the other code?
Thanks for the help
Old Aug 8, 2022 | 09:40 AM
Dontblink7's Avatar
Dontblink7
6th Gear
Do you know if the ebcm has to be programmed by a dealer once installed? Also, I should note that the vehicle drives perfect except for the message on the dic. Any insight on the other code? Thank you
Old Aug 8, 2022 | 09:43 AM
Dontblink7's Avatar
Dontblink7
6th Gear
when I purchased it, it had/has borla exhaust and k&n air intake
Old Aug 8, 2022 | 12:17 PM
grinder11's Avatar
grinder11
No, it is still driveable, but the anti-lock brakes will now be plain old school brakes. If the state you live in has an annual inspection, and the yellow icon showing a skidding corvette is lit, the car will not pass. If you don't want to chance a $1,000 used EBCM, remove the gauge cluster and then remove the bulb that lights the skidding car. Hopefully, the inspector won't notice the light no longer illuminates. Good luck.......
Old Aug 9, 2022 | 06:36 AM
Moved to C5 Tech.
To C5 codes
