Turn signals 2000 vet
Old Aug 8, 2022 | 08:02 AM
2079's Avatar
2079
Default Turn signals 2000 vet
I have an intermitten turne signal issue, were do i look for a loose connection or what else should i look for.
Old Aug 8, 2022 | 10:45 AM
MondoDave's Avatar
MondoDave
3rd Gear
Hi 2079,
Try pushing the hazard button in and out a couple times and see if the turn signal starts flashing (with turn signal already on). If so, there could be a hazard switch replacement in your future. There are some good guides already here on this site for switch replacement (some dash off, others not...).
Good luck :-)
Old Aug 8, 2022 | 11:27 AM
jdmvette's Avatar
jdmvette
Night Owl for life
Change this
Old Aug 8, 2022 | 12:00 PM
grinder11's Avatar
grinder11
Agree with above posts. Try the hazard switch first. If that doesn't fix it, you may need a new multifunction switch. That's what I had to buy to fix it. Just curious, define "intermittent." I'm guessing they hyperflash sometimes, or???
Old Aug 8, 2022 | 01:35 PM
2079's Avatar
2079
No. it looks as if I it a bump they go on or off.
To Turn signals 2000 vet
