Bad Td Relay
Old Aug 14, 2022 | 11:29 AM
andrewpasquale's Avatar
andrewpasquale
5th Gear
Default Bad Td Relay
Having problems with my 97 c5 and jumped out Tdr (4 Prong) and it started. Tried buying a replacement and all I can find are 5 prong plugs. Can I use the 5 prong in my plug? It has an extra plug marked 87a?
Old Aug 14, 2022 | 12:10 PM
666lisa's Avatar
666lisa
Yes 87a is use for something like blinkers back and forth from ecm or bcm.
Old Aug 14, 2022 | 12:30 PM
andrewpasquale
5th Gear
I changed it but still not starting unless I jump it out? Am waiting for a new shift cable (Auto).I did check out parking switch and was OK.
Old Aug 14, 2022 | 12:43 PM
mmartinez's Avatar
mmartinez
Can you hear the TDR click on when you turn the key to crank the engine over? Brief explanation of starting circuit, 12v leaves the Ignition switch goes to the Park safety switch, and then the positive side of the TDR coil. The BCM provides a ground to the other side of the TDR coil if VATS is OK.
Old Aug 14, 2022 | 12:51 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Just try your local Chevy dealer...these relays aren't more than $20.00...4 bladed relays are very common...don't know why you had trouble finding one ??
Old Aug 14, 2022 | 01:01 PM
andrewpasquale
5th Gear
Yes,can hear it
Old Aug 14, 2022 | 01:02 PM
andrewpasquale
5th Gear
was looking for the same 1 ,not a generic replacement.
To Bad Td Relay
