Led lights--radio problems
Old Aug 15, 2022 | 12:01 PM
glbeauchamp's Avatar
glbeauchamp
Default Led lights--radio problems
Installed a JVC KD-R 970 BTS stereo/cd player in my 02 a couple years ago. No problems until I switched to leds using a harness and flasher from Corvette Central. Now when I step on the brakes while radio is playing, the radio signal is replaced by static. Any ideas why? I haven't checked anything yet as the problem just occured and I am travelling. Thanks for any assistance.
Old Aug 15, 2022 | 01:25 PM
corvettezman's Avatar
corvettezman
St. Jude Donor '11-'12-'13, '15, '16-'17-'18-'19
My daughter had the same issue after LED installation in her Jeep Wrangler.
Installing clip on Magnets on the turn signal and headlight wiring helped some but not all the way Better. She thought the LEDs were more important to her than the radio, so I stopped trying to eliminate the problem completely.
It may have something to do with cheap LEDs being used that cause noise.
Amazon.com: (Pack of 20pcs) Clip-on Ferrite Ring Core RFI EMI Noise Suppressor Cable Clip for 3mm/ 5mm/ 7mm/ 9mm/ 13mm Diameter Cable, Black : Electronics Amazon.com: (Pack of 20pcs) Clip-on Ferrite Ring Core RFI EMI Noise Suppressor Cable Clip for 3mm/ 5mm/ 7mm/ 9mm/ 13mm Diameter Cable, Black : Electronics
Old Aug 31, 2022 | 01:34 PM
glbeauchamp
Installed magnets on led lights. Seemed to do the trick as static is gone. Thank you
To Led lights--radio problems
