"Charge system fault"
Old Aug 15, 2022 | 01:58 PM
Rawillenbrink's Avatar
Rawillenbrink
Cruising
Default "Charge system fault"
Hi my name is Ron, I have a 2000 C5 and I keep getting "Charge system fault" on the (DIC)..LOL I had the charging system checked out and all is well but they found out I have an Alternator for a Z06 when I should have an Alternator for an LS1. Could this be causing my Charge system fault alert?
Any Help appreciated.
Old Aug 16, 2022 | 05:36 AM
Choreo's Avatar
Choreo
On my 2001 the only time I ever saw "Charge System Fault" on the DIC was when I tried replacing alternators. Took me several alternators before I found one that would work reliably. Tried having my original Valeo rebuilt locally first, but they said it was toast.
Old Aug 16, 2022 | 06:15 AM
Rawillenbrink
Cruising
I was told it would not hurt anything to keep the alternator as long as I can put up with the DIC alert do you agree?
Old Aug 16, 2022 | 02:19 PM
SHOCheapRacing's Avatar
SHOCheapRacing
I did that for a year or so with my 2004 Z, the alternator finally crapped out at the track. I could not find one available within a couple hundred miles. I was able to order a replacement when I got the car back home delivered the next day. Lost two days at the track.
Start the search for the correct replacement while you have free time.
Old Aug 16, 2022 | 06:10 PM
Beast's Avatar
Beast
My alternator was replaced quite a few years ago by a rebuilt car quest product. It’s been fine all these years. My battery was dead back in March or April 2022, charged battery, got the charge system fault after start up, cleared the codes. It’s been fine all summer. It could be your alternator
Old Aug 17, 2022 | 06:27 AM
Rawillenbrink
Cruising
Thanks for the feedback...any suggestions on where I might find an original C5 alternator new?
Old Aug 17, 2022 | 08:32 AM
Beast's Avatar
Beast
Check your battery volts while driving. At idle you should be above 13.0 or 13.5 volts, something like that. When I did the alternator years ago, battery volts were dipping under 12.0 at idle.
Old Aug 17, 2022 | 12:21 PM
Rawillenbrink
Cruising
We just took a trip to bowling green Kentucky corvette museum and it never dropped below 13.
Old Aug 18, 2022 | 09:58 PM
lewislgZ06's Avatar
lewislgZ06
NCM Lifetime Member
St. Jude Donor '18 thru '26
The message is just there as a nag because you switched from the OEM Valeo.
When I upgraded to a Mechman 175 amp polished alternator, Vengeance Racing was able to go in with HP Tuners and turn the message off.
Old Aug 23, 2022 | 10:52 AM
mcbrucey's Avatar
mcbrucey
I only get this message when the car sits on the battery tender.
Old Aug 25, 2022 | 01:27 AM
Moved to C5 Tech.
Old Aug 25, 2022 | 06:55 AM
Rawillenbrink
Cruising
Hate to change out a perfectly good alternator just because of a "DIC" alert.
Old Aug 25, 2022 | 09:22 AM
WM-9c1's Avatar
WM-9c1
My alternator was failing so I had it rebuilt by a local guy and I had the charge system fault message after that, voltage was fine but the nuisance message would come and go while driving.
https://www.ebay.com/itm/290953992655
Someone posted a link to this voltage regulator in another thread and since installing it 4 months ago I haven't seen the message
To "Charge system fault"
