Troublesome drivers window
Old Aug 16, 2022 | 07:35 AM
Kmoylan's Avatar
Kmoylan
Default Troublesome drivers window
For some time my driver's side window has been screeching and grinding. Yesterday I rolled it down, it's still down now.. any solutions on how to raise it up, or fix it??
thank you..... Kevin
Old Aug 16, 2022 | 08:42 AM
Stingroo's Avatar
Stingroo
St. Jude Donor '20-'21-'22-'23-'24
You can pull the door panel off and try and put direct power to the window motor to see if it will operate. You can put positive and negative leads on either terminal on the motor. One way will send it up, and if you reverse it, it will go down.
It sounds like, though, the regulator has failed if the window went down fine the last time you used it. Typically these days most aftermarkets are sold as motor and regulator as a unit, making swapping easier.
Old Aug 24, 2022 | 03:27 PM
DDbird's Avatar
DDbird
Used Regulator from Corvette Part in Florida was 75 +Sh two weeks ago - that is what mine did -Motor was fine !!!!
Old Aug 25, 2022 | 12:07 AM
Moved to C5 Tech.
To Troublesome drivers window
