C5
Old Aug 20, 2022 | 10:02 PM
PeterC5's Avatar
PeterC5
1st Gear
Default C5
I have a 99 Corvette C5 my abs and traction light is on my Dash I've tried a few things does anyone know if a good solution to remove it from my Dash and my abs and my traction service will be good to use
Old Aug 20, 2022 | 10:13 PM
Smoken1's Avatar
Smoken1
Have you pulled the codes?
Old Aug 21, 2022 | 02:32 AM
corvettezman's Avatar
corvettezman
St. Jude Donor '11-'12-'13, '15, '16-'17-'18-'19
Codes, but then if it's a module issue, 97s to 2000s are not repairable.
You'll probably have to live with it as is unless you fork out the $$$$$ for a used one that you really do not know how long it will live. Last I was quoted for one of these was $2k.
There are no new stock modules available for C5s. Cross your fingers and hope that it's not that. That would be great news for you.
Old Aug 21, 2022 | 07:08 AM
Moved to C5 Tech.
Old Aug 22, 2022 | 07:17 PM
1999corvettels1's Avatar
1999corvettels1
When I bought my 1999 used in 2003 I got those messages once in a while.
Later found out someone before me put a lesser battery in car, lower cold cranking amps and reserve capacity, got correct battery and never got those codes again.
Can you tell us what battery you have in it, cca RC etc?
Just a guess but what if you think you are doomed and just have the wrong battery?
Also is the battery healthy, maybe have it load tested.
Worth looking into before going deeper.
To C5
