Fisrt C5 Mod????
Old Jan 6, 2003 | 06:16 PM
awaves's Avatar
awaves
Default Fisrt C5 Mod????
Just purchased a 2000 C5 10k miles. Unbelievable car. Its bone stock just curious as what mods to start with first. I've read some threads on the cheapo air box mod and aftermarket kits. Seems like the cheap mod gains about the same as the $500 kits, any thoughts???
Glad to be here!!
Old Jan 6, 2003 | 06:25 PM
Wolf1171's Avatar
Wolf1171
From: Winter Jam I and II Veteran, Bahama Jam 2005 Veteran
CI 4, 5, 7, 9 & 10 Veteran
St. Jude Donor '03-'05-'06-'08
Default Re: Fisrt C5 Mod???? (awaves)
I would go with an intake system, not sure on the cheaper systems. I think the Vararam is about $450 and the Blackwing about $300.
After that maybe exhaust.
Good luck and welcome :cheers:
Old Jan 6, 2003 | 06:29 PM
SvenOdin's Avatar
SvenOdin
Intake and exhaust is a good start.
There is usually some debate on which intake provides the most increase, but it's really subjective. They're all pretty close to one another IMHO.
Good luck!
:cheers:
Old Jan 6, 2003 | 06:45 PM
awaves's Avatar
awaves
Thanks, I think I'll try cutting my lid and give that a shot. All that I've read indicates that that a Vortex or Vararam give slight gains if any over just cutting the lid and popping in a k/n. It wont be driven in the rain, so not worried about the water issue. I'll apply the cash I save to a good exhaust, any recommendations?
Old Jan 6, 2003 | 06:48 PM
MarginalTraction's Avatar
MarginalTraction
If you are a leadfoot, you should consider a radar detector. I am happy with my Valentine V1.
Old Jan 6, 2003 | 07:32 PM
sick_vette's Avatar
sick_vette
[QUOTE]Thanks, I think I'll try cutting my lid and give that a shot. All that I've read indicates that that a Vortex or Vararam give slight gains if any over just cutting the lid and popping in a k/n. [QUOTE]
:iagree:
Old Jan 6, 2003 | 07:42 PM
Chris@SD's Avatar
Chris@SD
Astetically, not the best mod, but pretty effective. If you are just looking for results, you are not going to beat cutting the box. If you want a pretty good looking and effective intake that is not overly priced, the Blackwing is a pretty good mod. You can check some pictures out on our web site or in the CF mall.
If you have any other questions about what to do about your car, post away or drop me a line.
Good luck, and congrats on the car! :cheers:
Old Jan 6, 2003 | 07:47 PM
texasredc8's Avatar
texasredc8
Glad to be here!!
Oil Change with Mobil 1 and UPF44 filter
Magnetic Drain Plug for Oil Pan
Performance Air Intake (K&N w/ '02 Lid, Blackwing, etc)
Performance Exhaust
X-Pipe
Aftermarket Shifter (if MN6)
CAGS defeat (if MN6)
Powerloader (if A4)
Welcome to the wonderful world of Corvette ownership :seeya
Old Jan 6, 2003 | 08:00 PM
David Plum's Avatar
David Plum
Default Re: Fisrt C5 Mod???? (TexasRedZ06)
Is your car a4 m6 ? auto go w/converter .6 tenths and I recc. some kind of air cleaner before my vararam I bought a z06 lid and K&N worked well lid $ 42.00 filter ? m6 air cleaner/ mufflers almost a waist find some used on ebay.
Old Jan 6, 2003 | 08:31 PM
awaves's Avatar
awaves
Default Re: Fisrt C5 Mod???? (David Plum)
It's and A4, I think I'll put the converter on my to-do list as well. Thanks
Old Jan 6, 2003 | 08:37 PM
texasredc8's Avatar
texasredc8
You also would want to verify it has the G92, 3.15 Performance Axle. If it has the 2.73s then a performance rearend would be in your future.
Old Jan 6, 2003 | 08:49 PM
SlumpinC5's Avatar
SlumpinC5
How do you go about finding that out?
Old Jan 6, 2003 | 08:57 PM
texasredc8's Avatar
texasredc8
Default Re: Fisrt C5 Mod???? (Black_C5)
On a 2000 model, you can either look for the sticker in the glovebox, or pull the center cover in the "trunk" and look on the backside of the cover for the codes. You would be looking for G92. If you have that RPO code then at least your modding won't be totally in vain. If you don't have the 3.15s, then you might want to consider upgrading the rearend as your first mod.
Old Jan 6, 2003 | 09:05 PM
2CRUZIN's Avatar
2CRUZIN
Cold air.
:steering:
Old Jan 6, 2003 | 09:45 PM
awaves's Avatar
awaves
Default Re: Fisrt C5 Mod???? (fastfun)
great info on the gears, thanks.
Old Jan 6, 2003 | 09:54 PM
FYNL4's Avatar
FYNL4
Best bang for the buck? ....................Blackwing
Best bang for the soul?......................Corsas :thumbs:
Old Jan 7, 2003 | 01:36 AM
vetracn98's Avatar
vetracn98
St. Jude Donor '08
Default Re: Fisrt C5 Mod???? (FYNL4)
I agree with intake. I have the halltech tric air system and I love it. Like all the other intake it has what they say the hp gain is they say it is 30hp. I don't know if that is correct cause I din't dyno it after just that one mod. I did however feel a significant change in response, and the sound was changed also. I love it and recomend it to anyone. :steering:
To Fisrt C5 Mod????
Old Jan 7, 2003 | 01:47 AM
SlumpinC5's Avatar
SlumpinC5
I have a 99 but I'll take a look at the codes and see what I come up with...
Thanks for the tip...
Old Jan 7, 2003 | 02:26 AM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
ProFlow
Old Jan 7, 2003 | 05:32 AM
blktie8's Avatar
blktie8
B&B PRT'S and Vortex
My Sig says it ,gears next then headers and intake from 2001
