STREET- STREET/STRIP- STRIP
Old Jan 6, 2003 | 09:33 PM
PACEME's Avatar
PACEME
Default STREET- STREET/STRIP- STRIP
what stage shift kit should i be installing, need a little help. :confused: :confused: :confused: :confused: :confused: :confused:
Old Jan 7, 2003 | 04:37 PM
REDGAR's Avatar
REDGAR
Cruise-In II & IV Veteran
CI VI Drag Champ!
Default Re: STREET- STREET/STRIP- STRIP (PACEME)
Is this the trans-go?
I don't have it but I think the are firmess variants where street is the softest whiler firmer than stock adn strip is the firmest.
I'd choose middle of the road for myself and I make 200 passes a year.
Old Jan 7, 2003 | 07:05 PM
PACEME's Avatar
PACEME
Default Re: STREET- STREET/STRIP- STRIP (REDGAR)
Thats what i was thinking, but i dont know how hard the street/strip [middle] setting will feel. I was in my friends T/A with the strip[harddest] setting in his and it was chirping the tires at 1/4 throttle from 1-2 and 2-3. Ireally dont want anything like that. :smash:
Old Jan 7, 2003 | 07:24 PM
Chris@SD's Avatar
Chris@SD
The strip setting is the way to go, if you can deal with the head jerking shift.
The street/strip setting would be the way to go if the head jerking bothers you. The shift firmness on this is easy to get used to. You might also consider jumping up to a higher stall which will soak up alot of the grunt of the shift.
To STREET- STREET/STRIP- STRIP
