98 ECM DIODE Replacement - Pls Help Find
Notice its the only diode of its kind on the entire board.
The red pointer points to the Diode w the label GONE.
(SEE ATTACHED FILE for ADDITIONAL PICTURES including my ECM)
Hi to everyone. Im TJ, a new member with a98 Base Coupe. This is my first ever post on this website. I hope youre all enjoying your cars
and/or projects !!My PCM circuit board has a BAD DIODE on it, and, because money is tight right now and a repair service costs a few hundred bucks, my GOAL is to replace it as a Do-It-Yourself project.
Im hoping this can happen thru one of these Scenarios (preferably A):
Scenario A ----- from experience, someone knows, or can tell me how to ascertain, the diode Type and Value in Electronics Industry standard terminology: (EXAMPLE: Type: Zener diode; and Value: 5.1 Volts) ---- so I can then purchase the proper generic component from an electronics supplier such as Digi-Tek etc--VS--trying to acquire a good used GM diode. I realize this is a long shot.
Scenario B ----- someone can come up with the correct good used GM diode theyd be willing to sell me --OR-- tell me where or how I could a obtain one.
One problem here is that once my tech friend removed the corrosion from the diode, the part number / labeling was gone as well. (See 1st picture: Zoomed in on diode at end of red pointer). I searched the Internet for an image of a similar circuit board with that same diode to get the part # off of it NO luck. If anyone could provide that part number itd be a step in the right direction.
FYI the correct PCM Part # is 19332289, which is ALSO found in a 98 Camaro and a 98 Firebird ---- AND 16238212 is stated to also be a valid GM part # per Car-Part.com, as well as ECM service Flagship One. Additionally, multiple Techs have said that GM put the diode I need onto similar circuit boards in OTHER ECMs that cant be used in a 98 Vette ---- but I dont know which cars or part numbers for those ECMs.
I appreciate any help or input ! Thanks a lot ! TJ
(Sorry this post ended up getting pretty long.)
QUESTION: Can you tell me if I can get ANY valuable information by using my Harbor Freight multimeter, in Diode Test Mode, on the diode while still installed on the circuit board ? ______ (FYI -- When I said I’ll replace the diode, I meant I'll have my local electronics repair expert switch out the diode. That’s NOT something I personally can do ------- and ALSO my personal electronics knowledge is pretty limited.)
PS – Re what you used to do (in your Biography) – Shuttle etc. Holy Crap !!! Really cool !!
A. ONLY IF the test will prove that the diode is definitely good or definitely bad !!, (even ending up being only pretty sure is NOT worth trying this in my mind) ____ AND
B. ONLY IF the the leg can definitely be soldered back together with normal function restoredIF it turns out the diode tests as definitely good.
Phil, can you tell me if BOTH A & B are true?
PS – RE you’re mentioning that “This subject really belongs in the tech section.” Is that because there are more technically minded people there to contribute, or is this content actually “inappropriate” for the C5 forum? (I honestly don’t know because I’m new.) Let me know if there’s something I need to do about that. Thanks
What codes were you getting when you read them via the DIC.
Oh yeah, my dash display was reading “Reduced Engine Power,” and
my cheapo “HyperTough” Scanner gave me DTC codes: 0606 “ECM/PCM Processor” and 0518 “Manufacturer Control.”
My friend’s Snap-On Scanner said something like “Internal PCM problem.”
You can try measuring it, but without knowing what's in the circuit it could read anything. You would have to unsolder or clip one side of the diode and then measure it. This subject really belongs in the tech section. What codes were you getting when you read them via the DIC.
I dont have the tools or expertise to desolder and remove components, but I might be willing to clip the midpoint of the leg of the diode for testing --- BUT ONLY if the following is true:
PS RE youre mentioning that This subject really belongs in the tech section. Is that because there are more technically minded people there to contribute, or is this content actually inappropriate for the C5 forum? (I honestly dont know because Im new.) Let me know if theres something I need to do about that. Thanks
HE SAID, “If after a while you CAN'T FIND this diode and it is in fact BAD, THEN I would just buy a low signal diode and put it in the circuit and see if it works.Sometimes diodes are put in circuits for electrostatic protection.
To which I SAID, “That sounds like an awesome idea to me !!
PROVIDED THAT:
A. Someone can tell me EXACTLY what diode I can buy and use as a trial,
AND
B. There would have to be NO CHANCE that doing this could cause or allow damage to my ECM when I fire it up in my Vette as a trial – meaning, affecting the ECM in such a way that, if I DID later send it out for repair, the Repair Service might tell me it’s now UNrepairable as a result of trying a non-compatible / interchangeable diode !!! ”
So Phil, if you don’t mind my asking, what do you think?
(FYI – I don’t know what his background is.)
Unless the body of the diode is damaged it is probably good. What you have is possible moisture damage from bad seals on the connectors.
Gary
