Crankshaft position sensor change with headers
Old Sep 9, 2022 | 09:30 PM
Fast one's Avatar
Fast one
Default Crankshaft position sensor change with headers
How hard is it to change the crankshaft position sensor with long tube headers in the way, does the header need to be removed?
Old Sep 9, 2022 | 09:55 PM
Supercharged111's Avatar
Supercharged111
IIRC the starter's square in the way.
Old Sep 9, 2022 | 10:15 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Why is the sensor being changed ??…if it needs to be changed stick to an OEM sensor.
Old Sep 10, 2022 | 07:04 AM
grinder11's Avatar
grinder11
I think you remember correctly!! To the OP; I dont know if your brand of header requires removal, or not. But I'm pretty sure virtually every brand would have to be removed to drop the starter.......
Old Sep 18, 2022 | 10:39 PM
vinco's Avatar
vinco
I have a mini-starter on mine with long tube, and there's no way on the green earth that I could drop the starter without taking off the header.
Old Sep 19, 2022 | 05:51 PM
tommie's Avatar
tommie
When I did mine, I had to unbolt the header I did not have to remove it completely.
I had to unbolt the starter to access the Crankshaft sensor.
Mine was acting up when it got very hot. Replaced it several years ago.
To Crankshaft position sensor change with headers
