whine from engine compartment
Old Sep 10, 2022 | 01:58 PM
0145996's Avatar
0145996
Default whine from engine compartment
2003 C5 with about 85,000 miles. Getting a high pitched whine periodically from the engine compartment that doesn't change pitch with engine speed. I can shut the engine off and then just turn the key back on for power and the whine will return without the engine running. Looking for logical suggestions as to what it might be. I wondered if there is a pump of some kind for the anti lock brakes?
Old Sep 10, 2022 | 02:15 PM
Smoken1's Avatar
Smoken1
Is a cooling fan coming on? you could pull the fuses or the relays to see if it stops. I doubt it would be the ABS
Old Sep 10, 2022 | 11:08 PM
foggy's Avatar
foggy
Drive By Wire Throttle Body... It is energized with Key On... Some whine louder than others, but maybe your TB motor is going bad.
Maybe start with a good cleaning
To whine from engine compartment
