Kill switch/trackers compatible with c5?
Old Sep 13, 2022 | 01:58 AM
acefominC5's Avatar
acefominC5
Default Kill switch/trackers compatible with c5?
Title says it. Want to install some anti-theft measures in my car. Need recommendations
Old Sep 13, 2022 | 10:25 AM
Fast one's Avatar
Fast one
If a hidden SPST switch is added in series to either of the ignition key reader wires there will be two choices: normal operation or the car won't start. Or instead of the SPST switch, if a three position center off SPDT switch is added with a resistor value the same as the key to the switch there will be three choices; 1. normal operation, 2. no start and 3. key resistor no read overide (this bypasses the key resistor reader either to troubleshoot the contacts or to get the car started if the reader fails).
Old Sep 13, 2022 | 01:58 PM
feeder82's Avatar
feeder82
6spd tranny is enough these days
Old Sep 13, 2022 | 03:20 PM
acefominC5's Avatar
acefominC5
Facts 🤣 Still need a tracker. Something basic is okay
Old Sep 13, 2022 | 03:36 PM
G_Loc's Avatar
G_Loc
As for trackers, on the cheap and super basic end of the spectrum, you can always throw an AirTag into a crevice somewhere. It has it's limitations, biggest one being that the tag needs to be near an iPhone for it to work. If you want something more robust, a hardwired and well hidden GPS tracker with monthly subscription is your best bet:
Amazon Amazon
Amazon Amazon
Old Sep 13, 2022 | 03:40 PM
acefominC5's Avatar
acefominC5
https://www.amazon.com/Optimus-GB100...dp/B08SSWY8SH/
https://www.amazon.com/Trak-4-12v-Tr...dp/B07KDZ57HC/
Thanks for these links, will check them out. And man AirTag is a pos. Less accurate than a stormtrooper & updates location every fifteen years
To Kill switch/trackers compatible with c5?
