Battery’s Draining
Old Sep 27, 2022 | 07:48 PM
Rickny7@gmail.com's Avatar
Rickny7@gmail.com
Default Battery’s Draining
After sitting for a week covered in the driveway my sons C5 wouldn't start. We (I) bought a new battery. Now that battery is draining down as we sit in the driveway. 11.5 volts engine off, 14.5 with the engine running. And thats with a trickle charger on a brand new battery. Pulled several fuses but nothing seems to eliminate the drain. Any clues appreciated.
Old Sep 27, 2022 | 08:22 PM
03sonicywrx's Avatar
03sonicywrx
Here is a good starting point -
https://www.corvetteforum.com/forums...post1567522286
Personally had issues with headlight module causing the battery to drain, lights would flicker even when down. Now that it’s fixed haven’t had an issue since, no battery tender and the car sits for weeks at a time.
Old Sep 27, 2022 | 08:34 PM
TheBac's Avatar
TheBac
Possibly ignition switch? Same thing was happening to my car before the switch finally gave up.
Old Sep 27, 2022 | 08:50 PM
pauly1119's Avatar
pauly1119
St. Jude Donor '06-'11
Could be a bad battery. Wouldn’t be the first brand new battery I installed that was bad. 11.5 volts is a bad battery sign, the 14.5 is the alternator reading.
Old Sep 28, 2022 | 02:09 AM
Endless Money Pits's Avatar
Endless Money Pits
Does the car have any aftermarket electronics? Remote start? I would check things like that for a parasitic draw first.
Old Sep 28, 2022 | 03:26 AM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Old Sep 28, 2022 | 09:01 AM
Rickny7@gmail.com
thanks will follow up with that today.
To Battery’s Draining
