Power steering cooler delete
Old Sep 30, 2022 | 11:23 AM
YELLO C5's Avatar
YELLO C5
Default Power steering cooler delete
Had to unmount the power steering cooler and push it to the side to make room for the A&A supercharger intake piping. Thinking of removing it completely but I run one or two track events a year. Do I just need to splice the hoses? Is there a recommended fluid to better handle the heat for occasional track use?
Old Sep 30, 2022 | 04:14 PM
heggsc5's Avatar
heggsc5
Mine was just spliced together after the A&A install (had someone else install it). Although with a little extra work, I don't see why you couldn't just easily relocate it somewhere else. I'd like to believe having one in a less than ideal location is still better than not having one at all. I still have mine in the garage and it's just one of many low priority projects to get to haha
Old May 22, 2023 | 08:11 PM
C5Luv'R's Avatar
C5Luv'R
A C5 will boil the power steering fluid after 1 autocross lap without a power steering cooler. If you do any sort of performance driving, you want it. I agree with @heggsc5 that re-locating it is your best route.
To Power steering cooler delete
