engine sounds like it's tripping every few revs
Old Jan 8, 2003 | 03:35 AM
Blackjetvette97's Avatar
Blackjetvette97
Default engine sounds like it's tripping every few revs
Hi all,
I noticed my engine sounds like it "trips" every few revs or so. I have done the PCV mod with the compressor filter and have a little bit in there with the filter a light brownish tint. Is this restricting the PCV enough to screw up the idle? Are my plugs bad? Coil pack bad? Damn, now that I noticed it, it is driving me batty!
Steve
Old Jan 9, 2003 | 10:12 AM
Duck916's Avatar
Duck916
Default Re: engine sounds like it's tripping every few revs (Blackjetvette97)
Is this a new problem? Mine has always felt like it misses every few seconds at idle, and I have noticed this on several other cars as well. Is that what you're experiencing?
Old Jan 9, 2003 | 11:05 AM
wwashing's Avatar
wwashing
Thge early years ('97, '98) have what seems like a slight stumble in the idle and that is normal.
A minor change (different plugs?) was made in '99 to improve the idle, but I think they all have some slight lumpiness in the idle.
Do you know that your idle has changed from before you did the PVC mod? :cheers:
Old Jan 9, 2003 | 11:11 AM
Scissors's Avatar
Scissors
☠☣☢ Semper Ebrius ☢☣☠
Cruise-In IV-V-VI-VII Veteran
St. Jude's Donor '06
Default Re: engine sounds like it's tripping every few revs (wwashing)
As near as I can tell, the lumpy idle is a trait of all cross-plane V8s with a single cam.
To engine sounds like it's tripping every few revs
