Only for the left tank the right side ones are gone
I wasn't talking about the whole jet pump assembly.
I am talking about replacing just the sending unit with a new GM sending unit. If that is all that is needed for the failure at hand. The sending unit itself just snaps into the base on both sides identically. The wiring is identical. The resistance value is identical..
In the GM instructions it shows how to install it in either side IIRC. I'd double check or triple check if I hadn't thrown them out already.
I have both my original sending units in the garage from my car. They are the same. The wire rod that holds the float is slightly different left to right but the float lands in the same spot, and if one was being **** that can be swapped out if desired although the GM instructions didn't say it was needed.
What symptoms are you experiencing. Are you getting the fuel gage drops to zero after about 100 miles or something? Any codes?
The tanks hold 18 gallons combined. As stated above, calculate how far you can go with half the fuel and carry a gallon of gas when close to that threshold.
Yes been getting the gauge drops to zero and after resetting the DIC code P1431 it goes back up. When I fill up at about 200 miles and gauge only goes to 3/4 tank and takes about 7 gallons. Going to probably do the can thing and see if it’s transferring fuel or not just worried about it restarting if I run out. It’s a 2000 manual. Just very annoying. Been using the Techron and sea foam for about a year without much luck
Speaking from experience and going almost 3 years without a functional fuel gauge from multiple failures.
The solution for me was to stop procrastinating and just drain the tanks and replace the parts. In the grand scheme of things it's not nearly the scary monster that our brains want us to believe that it is.
While I never did have a clogged jet pump I did have a bad sender in the right hand tank. For the right side I bought the assembly that comes with an updated jet pump.
Left hand tank ultimately got a new sender as well. Now it goes to full and returns to empty without the half hour time out gauge drops to zero check gauges message lol.
Also if you have a good late model scan tool it may have the ability to see your fuel sender voltages real time. This will show you what is going on in the right tank real time.
I happened to us my HP Tuners Scanner channel functions for this task.
So even after changing the sensors etc you still have the same problem. To bad someone can’t come up with a solution that would fix this problem as so many have had the issue
No, no, sorry about that if I made it confusing. I DO NOW have a fully functioning system. So nice to have accurate fuel gauge and not have to listen to the gong when check gauges pops up.
I was able to get factory GM parts from rock auto to fix everything.
I do believe the factory parts are getting harder and harder to find in stock.
I have been down this road. The jet pump works of a siphon if it's not transferring fuel from the right tank to the left tank then it can only be a couple of things.
1.something is breaking the siphon
2. The pump is stopped up.
3. The check valve in the siphon pump is clogged up.
This is what I done, and yes it is a pain in but. Drop the cradle and remove both fuel tanks. Once you have both tanks out remove both pumps. Inspect the lines for any cracks or anything that could break the siphon. Check the siphon pump for any clogs. If you find nothing take 2 five gallon buckets and fill each one half full set your pumps down in them and hook them to a battery you should see the siphon pump transferring fuel to the other bucket. If not and there is no hole in any of the lines breaking the siphon the Check valve is stopped up. This was the case with mine I sprayed some carburetor cleaner up in it and pecked on it a couple of times with a screwdriver put the tanks back in the buckets and hooked up the battery again. The siphon pump sputtered a couple of times and blew out some trash and has worked just fine ever since.
I guess if I keep driving it and get over 250 miles with out running out of gas it would be transferring from the jet pump and just a sensor, am I thinking right ?
PartsHawk on ebay has new GM MU1218 (2000-2003) complete Jetpump and fuel sender assembly for 280 right now. While that sounds terrible I will say that he current price at Summit or Jegs for the same part number is 600.00.
This may be pedantic, but...
The jet pump does not work on a siphon principle. Here is how it works:
The incoming high pressure flow from the left pump passes through a nozzle that converts high pressure to high velocity flow through Bernoulli's principle.
The high velocity flow exiting the nozzle collides with fuel coming in through the right angle inlet from the right tank, and through the principle of momentum exchange results in higher flow lower pressure exiting the pump to go to the left tank.
Comparing energy in to energy out, the process is not very efficient, but has the advantage of no moving parts, no electricity, etc.
It is usually the small diameter nozzle that gets plugged.
Just for grins, here is one of the jet pumps from a Cessna 750 Citation X:
It is about a foot long. There are three jet pumps per side: one transfers fuel from center tank to wing tank (shown), one transfers fuel within wing tank to feed bay, one feeds the engine from the feed bay and also provides motive flow to the other two. The feed ejector motive flow is provided by an engine driven pump at about 300 gph at about 475 psig.
