no cruise control....
Old Oct 10, 2022 | 10:04 AM
clutch1's Avatar
clutch1
Default no cruise control....
1999, FRC....My Cruise Control isnt working...Have a Service Traction light on the dash...If cruise isnt working will it turn on that light?...John.
Old Oct 10, 2022 | 10:10 AM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
If you don’t have a scan tool check for DTC’s through your DIC…may help in a diagnosis.
Old Oct 10, 2022 | 11:23 AM
clutch1's Avatar
clutch1
will do tonight...Could it be just a fuse?.......
Old Oct 10, 2022 | 11:33 AM
C5 Diag's Avatar
C5 Diag
The cruise is probably not working because of the TC !!…could be anything but first you have to see what codes are stored… unfortunately there is not one easy fix for every issue.
Old Oct 10, 2022 | 01:34 PM
clutch1's Avatar
clutch1
Thanks........
Old Oct 11, 2022 | 08:40 AM
clutch1's Avatar
clutch1
All fuses are good..........All tail lights good..Will scan for codes tonight.......How long can I drive the car with the Service Traction light on?...........John.
Old Oct 11, 2022 | 08:53 AM
Yello95's Avatar
Yello95
St. Jude Donor '11
did you try the reset button?
Old Oct 11, 2022 | 11:21 AM
clutch1's Avatar
clutch1
yes, nothing Happened.........................All this is after I got the car back from the body shop...was ok when i took it in..
Old Oct 11, 2022 | 11:31 AM
C5 Diag's Avatar
C5 Diag
You should have mentioned that all this happened after you took it in to a body shop…what was done to the car ??…I’d take it back there and let them handle this.
Old Oct 11, 2022 | 12:18 PM
clutch1's Avatar
clutch1
They put a diffuser on.....left out one back up light too.....
Old Oct 12, 2022 | 09:03 AM
clutch1's Avatar
clutch1
ok, All fuses good, I scanned for codes, abs ,body, all of it NO, codes....Started the car up, NO Light.....Drove it up and down driveway, light never came back on..The button will turn on the light, where it dident before............So for now guess its ok..................John..........
Old Oct 12, 2022 | 03:42 PM
clutch1's Avatar
clutch1
Well ok then.................
Old Oct 13, 2022 | 11:43 AM
clutch1's Avatar
clutch1
Old Oct 14, 2022 | 11:23 AM
clutch1's Avatar
clutch1
2019 OPEN CAR SHOW....Houston Tx...
To no cruise control....
