Secondary air pump po code 410
The PCM monitors the HO2S voltages to diagnose the AIR system.
During the AIR test, the PCM activates the AIR pump during closed loop operation. When the AIR is activated, the PCM monitors the HO2S voltages and short term fuel trim values for both banks of the engine. If the AIR system is operating properly, the HO2S voltages should go low and the short term fuel trim should go high.
If the PCM determines that the HO2S voltages for both banks did not respond as expected during the tests, DTC P0410 sets. If only one sensor responded, the PCM sets either a DTC P1415 or P1416 to indicate on which bank the AIR system is inoperative.
Do you have vacuum at all on any of these lines when engine is runnning ?
All of these items in this diagram (fuse,relay, pump , solonoid )must be operating in order to get oxygen pumped into the exhaust manifoils
It is a drain into the engineroom shown on this photo (rubber elbow)
The line number 2 is going to the air solonoid
The line number 3 is going to the vacuum manifoil inside the car
Here is a very good write up with good pictures of the vacuumlines inside the car
Hope this helps
Connect a new plastic line to the rubber elbow and reconnect the rubber elbow back onto the sourcepoint on the intake(below the MAP sensor).
If not this works out I think you have to remove the intake
