Z06 Grill Screens
Old Jan 8, 2003 | 04:21 PM
Funn One's Avatar
Funn One
Default Z06 Grill Screens
I going to put some cold air ducts on my 98' tonite that i just purchased . and i am going to put order in for Zo6 grills. do these two piece's have to be put on together. i dont want to have to take it apart twice :boxing
Old Jan 8, 2003 | 07:18 PM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI II, III, IV & V Vet
CI IV Bracket Champ
St. Jude Donor '03-'04
Default Re: Z06 Grill Screens (tripblkvert)
welcome aboard and I would do them at the same time :cheers:
Old Jan 8, 2003 | 11:38 PM
DsC5's Avatar
DsC5
welcome. :cheers: It is much easier to drill some holes in the stock fog light surrounds than to install the cold air screens. If you want to go the aftermarket surround way - I can help you with the install, just shoot me an email. Either way - you can do it separately, but if you add the Z06 screens - it is easier to do that step last, after installing the cold air surrounds or drilling the stock ones. :seeya
Old Jan 9, 2003 | 12:05 AM
0-60N4's Avatar
0-60N4
I actually removed all the stock stuff, but I bought the Vararam kit to fill the holes. The Z06 screens according to the Dealership I went to, said you do not need anything behind them. You will need to buy screws or body clips to attach them to the car though. I used body clips, for $2 at any local parts store.
Old Jan 9, 2003 | 12:09 PM
spicoli25's Avatar
spicoli25
Default Re: Z06 Grill Screens (0-60N4)
Depending which Z06 screens you decide to install depends on the installation. I installed the front Z06 screens using a very simple velcro system. I installed velcro on the inside of the bumper hole and on the top and bottom of the screens. Then when you push them in they will be real tight and fit flush without taking the front of the car apart. Easy and it works. You cant even pull them out by hand without alot of force. Looks great either way you decide. [IMG][/IMG] http://pic5.picturetrail.com:80/VOL7...0/14726182.jpg
[Modified by spicoli25, 12:11 PM 1/9/2003]
Old Jan 9, 2003 | 04:04 PM
Funn One's Avatar
Funn One
thanks guys the info helped :seeya
Old Jan 10, 2003 | 01:44 PM
BAMAGOLFER's Avatar
BAMAGOLFER
St. Jude Donor '06-'10-'11
Is there a thead that details the removal and instalation of the old solid fillers for replacement by cold aid ducts by the fog lights.
Old Jan 10, 2003 | 03:04 PM
Patches's Avatar
Patches
Default Re: Z06 Grill Screens (BAMAGOLFER)
I had rhe bumper cover off when I pulled mine but it's not necessary. Here's a pic of the stock filler.
To Z06 Grill Screens
