Rescue Vette Saga $$$
I've posted before about the '97 I bought with an LQ9 in it. From the moment I got the car it was nothing but trouble. From the crank bolt backing out, to vacuum leaks, burnt wires, mis-fit headers, and front suspension issues that could've killed me, and of course torque tube couplers shot. Got most of all that fixed, except for the cheap e-bay injectors. Then a backfire that split the intake manifold. So, back to shop it went. It's been there longer than I should probably tolerate, however, this place is more than fair in pricing and are experts in Corvette and LS engines.
Fast forward, he tells me that he got the block back and said he highly recommends that I don't use it. He thinks that a cylinder got hydrolocked, bent a couple of rods, caused damage to the block. Not quite sure on specifics yet, but I'll get more details tomorrow. However, he said he does have an LS3 he can put in. More details to come on that as well, but he said he estimates about 500 whp out of it.
I have a couple of questions, though. The LQ9 had 243 heads, which are good as far as I know. He did say the block was repairable, and I'm sure there are some other usable parts. I know the 243 heads won't work on an LS3, and i really don't have the time or desire to try and sell them myself, but I know they have a pretty good value. Any tips on how to negotiate that deal towards the cost of the LS3?
The other part, and I suppose I can google it, but I would rather just hear it from those that have been there, done that. What do I need to ask about and look for on the LS3 to make certain I'm getting my money's worth? Not that I don't have a reasonable amount of trust here, I've talked to several people that have work done here and each one had nothing but good things to say, but I don't want the make that same mistake that I did buying this car in the first place. LOL.
Second, in order to generate 500 rwhp, the engine needs to produce roughly 550hp. You might want to ask what modifications have been made.
Third, used 243 heads bring about $600/pr on EBay.
Best of luck!
Get whatever you want since that engine is junk, but there is no benefit of any one over any other which is a used product in terms of guarantees it will work. Also, depending on what an "LS3" costs you, you might still be better off building or rebuilding another LS. In my mind I see HP / $, not model names or displacements. So LS1 / 2 / 3 / 6 / 7 / 9 doesn't matter to me as much if a 500hp LS3 costs $9k but a 500hp LS-whatever costs half and leaves you with money to invest elsewhere as needed.
Tough spot.
Good luck.
Tough spot.
Good luck.
Hindsight being 20/20, this is that car I should,ve walked away from. But I didn't, and now it's mine. Once the powertrain is done, I already have most of what I need to make a respectable driver car out of it. This is why I call it "rescue Vette", it's like one of those great dogs that got abused by the original owner.
That's been my year as well. Not with the Vette, as it never came out of storage this year
. But every other car in the fleet has decided this was the year to break.
Keep us posted on what you decide.
The only other more expensive car I like are the Ford GTs. But I still just love the clownshoe Gen 2 Vipers... The bodywork design is sex on wheels and the interior is no frills, just wraps you into it. I'd be psyched. But I guess I have to still have goals, eh? ✌️😁
So now the plan is to find something significantly cheaper to get it rolling. I plan on keeping it, but if I have to sell it, I'd like it to be running. Pretty worthless otherwise.
