C5 shocks f45
Old Oct 21, 2022 | 10:06 PM
Garymelle's Avatar
Garymelle
4th Gear
Default C5 shocks f45
Need help here guys 1998 c5 had to get a bcm my car does not have ride control and now have the f44 code shocks inoperable code I have a tech 2 and still can’t get it off plz help
Old Oct 21, 2022 | 10:39 PM
Smoken1's Avatar
Smoken1
Have you tried removing the option with the Tech 2 and you can't get rid of it?
Old Oct 22, 2022 | 01:58 AM
Garymelle's Avatar
Garymelle
4th Gear
correct can’t get it off even with the scan tool tech 2
Old Oct 22, 2022 | 10:45 AM
Johnny Hardcore's Avatar
Johnny Hardcore
You likely just aren't doing the procedure correctly.
Hopefully that's the case anyway. This link and embedded link should help.
https://www.corvetteforum.com/forums...-and-25-a.html
Old Oct 22, 2022 | 03:07 PM
Tusc's Avatar
Tusc
Running Guns & Moonshine
IIRC....
....you first need to disconnect the computer in the driver side trunk compartment. Once you get the Tech 2 to remove F45 from the car software, you then cannot plug that computer back in or it may re-load in the car.
I forget the steps needed in the Tech 2 tree itself.
Old Oct 22, 2022 | 04:05 PM
Garymelle's Avatar
Garymelle
4th Gear
Like I said my car does not have that module car does not have ride control thx
I forget the steps needed in the Tech 2 tree itself.[/QUOTE]
Old Oct 23, 2022 | 01:57 AM
Smoken1's Avatar
Smoken1
Since you replaced the BCM have you done the "BCM/PCM relearn" so the modules will communicate with each other?
Old Oct 23, 2022 | 10:00 AM
Justin Raney's Avatar
Justin Raney
Dont mean to interupt but does anyone know someone in san antonio texas with a tech 2 gm software to turn off the f45 or f55 so i dont get service rtd on display?
To C5 shocks f45
