Forward tilt radiator resources
Old Oct 26, 2022 | 09:26 PM
absintheisfun's Avatar
absintheisfun
Default Forward tilt radiator resources
I have been toying with the idea of converting my c5 from a bottom feeder to a front pull setup by tilting the radiator forward and doing some body mods. It seems like I would need to modify the front frame crossmember. In an effort to save time, resources, and potential setbacks I'm wondering if there are any resources that are out there that may provide some insight on the best way to tackle the project. Here are about the only resources I've found so far...
https://nasaspeed.news/tech/engine/rocket-science-achieving-better-engine-cooling-with-proper-aerodynamic-principles/
from this forum:
https://www.corvetteforum.com/forums/autocrossing-and-roadracing/4363414-c5-lay-down-forward-radiator.html
Old Oct 28, 2022 | 06:46 PM
ipuig's Avatar
ipuig
St. Jude Donor '09
Why?
Old Oct 28, 2022 | 08:40 PM
absintheisfun
Originally Posted by ipuig
Why?
the car is a dedicated track car in Texas. Pretty much every track day in August and September led to much higher temps than I was comfortable with.
Old Oct 29, 2022 | 07:48 AM
ipuig's Avatar
ipuig
St. Jude Donor '09
You would be better off posting this question in the autocross and road racing section.
Old Oct 30, 2022 | 08:27 AM
absintheisfun
Will do, thanks for the tip
Old Oct 31, 2022 | 04:08 AM
vette4fl's Avatar
vette4fl
Just curious, do you already have a DeWitts radiator and a high flow water pump?
Old Oct 31, 2022 | 08:26 AM
3X2's Avatar
3X2
Just throwing this out there. C7 has a forward leaning radiator. Maybe a C7 lower radiator support and radiator mounting would fit and use a C7 radiator????
Old Oct 31, 2022 | 12:41 PM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
G speed has a kit. The Autox and Road Race section would have more.
To Forward tilt radiator resources
