Engine Power Help/Diag
Old Oct 29, 2022 | 06:32 PM
g3t0ut's Avatar
g3t0ut
Cruising
Default Engine Power Help/Diag
Hi all, Hoping someone can give me a little help!
So issue is that when ABS faults the car shuts off.. We found this issue while the car was on the Dyno since the front wheels don't move.
the car turns on and runs and once moving and the car realized the front wheel speed is not correlating and the ABS light pops it shuts off.
If you cycle the key it comes back.
My next thought was pull the ABS fuses and see if it runs. NO start
put the fuses back and pull the ABS module plug, again NO start.
It will turn over but wont run
My car does have a ls7 swap and my guess is somehow some power wire is not where it should be?
I was hoping someone could give me a list of what wires need power to keep the engine running since I figure I will rewire those. I suspect this would be easier then tracing all the ABS wires?
Any thoughts/ ideas otherwise I am all ears.
All help and advice appreciated!
