Climate control display
Old Oct 29, 2022 | 09:41 PM
twoC5s's Avatar
twoC5s
2nd Gear
Default Climate control display
The climate control display screen of my 2003 C5 is blank. The appropriate fuse is not identified in the owner manual. I don’t know if it’s the fuse or the bulb. Can anyone help?
Old Oct 29, 2022 | 09:56 PM
Route99's Avatar
Route99
St. Jude Donor '17 thru '26
Welcome to the Forum!
Bummer about the climate control. I would recommend asking your question in the C5 Tech section which will get your question in front of the experts there. This is more of a general “hello” section.
When you ask the question, please include a little more info that could help you receive better answers. Did the screen just go blank? Is the climate control working but just not showing the display info? Do you have any codes related to hvac on your DIC? Additional info like that will help greatly.
Best wishes for an easy fix.
(Could be fuse 27 but, again, more info is needed).
Old Oct 29, 2022 | 10:03 PM
Moved this to C5 Tech for some assistance with your question.
Old Oct 29, 2022 | 10:04 PM
kkupec02's Avatar
kkupec02
welcome
Old Oct 29, 2022 | 11:36 PM
jdewolf's Avatar
jdewolf
Does the unit work other than just the display?
Old Oct 29, 2022 | 11:50 PM
Gixxerman's Avatar
Gixxerman
Moderator
St. Jude Donor '18 thru '25
welcome
Old Oct 30, 2022 | 02:21 PM
grinder11's Avatar
grinder11
Originally Posted by Gixxerman
welcome
Welcome to the forum. Call Travis@Vettetronics. (618) 975-3607. I'm assuming you have Dual Zone HVAC? Travis is good, fixed mine, including a bad circuit board...
Old Oct 30, 2022 | 03:23 PM
Smoken1's Avatar
Smoken1
If you can solder they are easy to fix
Old Oct 30, 2022 | 04:15 PM
mmartinez's Avatar
mmartinez
There is no bulb, what generally happens is the surface mount resistors were not solder correctly and they tend to lift of the PC board. I pulled my climate control and retouched and added a small amount of solder to those resistors.
Old Oct 30, 2022 | 11:28 PM
magneticred's Avatar
magneticred
This may address your issue:
https://www.corvetteforum.com/forums...splay-fix.html
Old Nov 1, 2022 | 01:38 PM
grinder11's Avatar
grinder11
Yes, this worked for me, too. But I still had some bulbs burned out that needed changing. The display itself has LED's, correct?
Old Nov 1, 2022 | 01:50 PM
jdewolf's Avatar
jdewolf
No, they're bulbs that can be changed out for LEDs. The display itself is a LCD.
Old Nov 2, 2022 | 04:34 PM
Elektro's Avatar
Elektro
^^VFD. The buttons are lit by bulbs that can be replaced by LED but the display is VFD.
https://en.m.wikipedia.org/wiki/Vacu...escent_display
The VFD doesn't fail but the soldering will need to be redone. While you are in there you can replace any bulbs with new bulb or LED.
https://m.youtube.com/watch?v=s_K_Yc19dFQ
There is another youtube on changing the bulbs.
You can see what I wound up with: https://www.corvetteforum.com/forums...post1605446007
Old Nov 3, 2022 | 12:28 PM
grinder11's Avatar
grinder11
Are you 100% on LCDs? I was under the impression LCDs freeze in cold climates. In Michigan, we see -20°F in some Winters......
Old Nov 8, 2022 | 11:46 PM
jdewolf's Avatar
jdewolf
VFD, I was corrected earlier
Old Nov 14, 2022 | 12:53 PM
grinder11's Avatar
grinder11
What does VFD stand for? Guessing the "F" is for Fluorescent.......
Old Nov 14, 2022 | 03:11 PM
SilverC54me's Avatar
SilverC54me
Vacuum Florescent Display
Gary
To Climate control display
Old Nov 14, 2022 | 03:23 PM
Dads2kconvertible's Avatar
Dads2kconvertible
One option is a repair from here: https://www.ebay.com/itm/133811755346
I've seen a write-up on dismantling the unit but can't seem to locate it at the moment.
Old Nov 19, 2022 | 11:43 AM
Cherry3m's Avatar
Cherry3m
Fixed mine today. Super simple. You don’t have to be a soldering pro to do this.
Old Nov 19, 2022 | 09:55 PM
feeder82's Avatar
feeder82
All this good advice and the O.P. never heard from
