recommendations on motor oil?
Old Jan 9, 2003 | 09:27 AM
Darrell G's Avatar
Darrell G
Default recommendations on motor oil?
I just bought a 2000 coupe and don't know what oil the previous owner used. I use Mobil 1 in my C4. Also what about viscosity/weight? I live in Texas so get warm days mixed with below freezing this time of year.
Old Jan 9, 2003 | 09:32 AM
wwashing's Avatar
wwashing
Default Re: recommendations on motor oil? (Darrell G)
Mobile-1 10w30. :cheers:
You could switch to 5w in the winter.
[Modified by wwashing, 8:34 AM 1/9/2003]
Old Jan 9, 2003 | 10:13 AM
gmblack3's Avatar
gmblack3
Default Re: recommendations on motor oil? (wwashing)
:iagree:
Old Jan 9, 2003 | 10:22 AM
Tom/99's Avatar
Tom/99
Mobil 10W-30 is all I use in my Corvette's.
Old Jan 9, 2003 | 10:27 AM
c5chris's Avatar
c5chris
I use Mobil 1 5W30 or 10w30 since both of them are the recommended viscosity.
Old Jan 9, 2003 | 02:21 PM
Touringpro's Avatar
Touringpro
I run Mobil1 10W-30 year around in the PT and Tundra (and in the '99 Coupe when I owned it), Mobil1 15W-50 in the Harleys, and Castrol GTX 20W-50 in the C3. It's often over 100F here in the summer, and doesn't get much below 35F this time of year.
Use a quality filter too. Personally, I like Wix, Mobil1, K&N, Bosch Premium, AC-Delco, and SuperTech (Wal-Mart).
Old Jan 9, 2003 | 02:24 PM
1g1yy's Avatar
1g1yy
Use Mobil 1 5w-30. It flows better on start-up and is the same weight as 10w-30 after it heats up. :yesnod: :cheers:
Old Jan 9, 2003 | 04:24 PM
Richin Chicago's Avatar
Richin Chicago
Mobil 1 10W 30 as it has a better VI than 5W 30 and you are not going to have weather below 0 F. Also use a Delco UPF 44 filter.
Old Jan 9, 2003 | 04:30 PM
carpe dm's Avatar
carpe dm
Stick with the recommended 5W-30; good qualities as noted above. Amsoil is another excellent oil! :yesnod: :)
Old Jan 9, 2003 | 04:36 PM
1SlowC5's Avatar
1SlowC5
I use 10w30 Royal Purple, Mobil 1 is also very good. :cheers:
Old Jan 9, 2003 | 05:45 PM
Smokin Joe's Avatar
Smokin Joe
Redline.
If you run your car hard...use 10W30...no matter what brand.
Old Jan 9, 2003 | 05:57 PM
SwissVette_Joe's Avatar
SwissVette_Joe
Darrell G
I totally agree and sign-up what "Rich in Chicago" already said (for the Oil Filter as well => UPF44, instead of PF44). Following the GM SVC Manual, you should use a minimum weight of a 5W - depending on temps, better use a 10W (this is cold viscosity index).
IMHO, I would go even one step further : if you intend to use your Car for what it is really built, some kind of very spirited, enthusiastic driving, then you might choose even a 10W-40 (GM does approve this weight for the C5).
However, you also should check to respect API "SJ" (min.) and/or ACEA A3-96, 100% synthetic.......or then the GM definition Starburst 4718M.
Good luck to you. I personally use, and this to my overall satisfaction : RED LINE HigPerformance Lubrication - from Bumper to Bumper. Engine 10W-40 -- A4-Tranny D4-ATF -- rearend 75W-90 (the latter contains already the necessary friction modifier, so no further mixing adventures necessary).
Joe.
Old Jan 9, 2003 | 07:35 PM
Blue 02 C5's Avatar
Blue 02 C5
I use Mobile 1 0w30 and will switch to 0w20 when it comes out in March 2003. :)
Old Jan 9, 2003 | 07:49 PM
SwissVette_Joe
Default Re: recommendations on motor oil? (Blue 02 C5)
Blue,
just be careful pls. Re GM SVC Manual, they do prescribe a minimum oil weight of 5W-30. Any lower could be, IMHO, a really too thin "watersoup" - may be lack of sufficient lubrication capabilities.
I think you would not want to hurt your engines internals. Keep in mind the temps within bearings and other highly critical areas of your engine. Just my .2 cents. If you really like THIN, for whatever reasons, go with with 5W-30 - this represents the possible minimum of viscosity. Good luck.
Joe.
[Modified by SwissVette_Joe, 1:53 AM 1/10/2003]
Old Jan 9, 2003 | 09:42 PM
twincam47's Avatar
twincam47
Default Re: recommendations on motor oil? (SwissVette_Joe)
I also use 10-30 Mobil 1
And not to steal the thread but
my Dad has an 02 Ford pickup with a
4.6 liter engine......right on the oil fill
cap it says 5w20......You could have pushed me
over with a feather.....Might as well use wd40
:crazy:
and hey Joe I just noticed your modified post date and time....kinda different
in another country.....regards WK
[Modified by twincam47, 8:44 PM 1/9/2003]
To recommendations on motor oil?
