Hesitation during left hand cornering
Old Nov 10, 2022 | 12:56 PM
jamesm007's Avatar
jamesm007
3rd Gear
Default Hesitation during left hand cornering
Hello! New member here. I have been reading these forums for a while now and I need some help myself. I have a 2003 Corvette Coupe. Everything is stock no mods. Mild cornering towards the left I have hesitation (mild to medium), as long as I am in the turn. It's like a surging. I don't get any messages in the dash. The engine runs fine and even just turning left I have NO hesitation. Only when in a left hand sweep, going onto the freeway. Anyone had the same or ideas?
Old Nov 26, 2022 | 02:00 PM
jamesm007's Avatar
jamesm007
3rd Gear
Default a cheap bump... sorry
its a tough one I guess. I was just hoping it was some common c5 coupe problem
Old Nov 26, 2022 | 06:42 PM
RonSSNova's Avatar
RonSSNova
Fuel pickup problem? Does it do it with a full tank?
Old Nov 26, 2022 | 09:58 PM
jamesm007's Avatar
jamesm007
3rd Gear
Yes, even with full tanks. However, it doesn't do it at slow speeds. just above slow speed will induce the surging. If I look at the tack while its doing it, its quickly going up/down ~100 rpm. Strange I know.
Old Nov 26, 2022 | 10:06 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
I’d check for any stored trouble codes using the DIC…may give you some direction.
To Hesitation during left hand cornering
