Air Bag Removal Question
I'm replacing the stock steering wheel on my 98 C5, and following a couple of Youtube videos on the subject, I inserted a 2 ohm resistor in the former airbag connector terminals. Problem: I'm still showing an airbag problem light. Did I miss another step?
Along the lines of what @mmartinez is saying, if you have an airbag fault light, then there will be an airbag system fault code. Try clearing that in the DIC, and see if the light turns off and stays off. Sometimes for this type of system you have to manually clear the fault for the system to reset the fault light.
marco383 (11-18-2022)
Received 1,789 Likes
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
I have a resistor in mine with an aftermarket wheel and I still get the airbag light once in a while. Clearing the codes in the DIC makes it go off for a bit. Slightly annoying, but not bad.
