Battery group 78
Old Nov 17, 2022 | 03:29 PM
stnick's Avatar
stnick
Default Battery group 78
So my last ac/delco 42 month battery installed 6/11/13 has failed…( 9 years 5 months) of course im searching high and low for another 42 month ac/delco in huntsville al with no luck so far.
ive read on here that the group 78 will fit without any concerns/issues at all… width and height are a little less but length is 1.250 more? If the bottom sits in the tray, why not go with the higher capacity reserve and cold crank amperage ?
Thank to all that have the 78 in your baby…
Nick
Old Nov 17, 2022 | 04:11 PM
C5MSG2004Vert's Avatar
C5MSG2004Vert
I used a group 34 battery with the higher capacity on my 04. Group 78 is essentially the same size with side terminals. It actually is a pretty tight fit in the tray but it mounted fine.
Old Nov 18, 2022 | 02:43 PM
stnick's Avatar
stnick
Thanks or that reply and the info… I found a acdelco 42 mth so Im hoping for 9 1/2 years out of his one😂😂
Old Nov 18, 2022 | 04:56 PM
JHrinsin's Avatar
JHrinsin
If I remember correctly;
1997-00 came from the factory with Group 78 wet cell battery (can be upgraded to Group 78 AGM)
2001-03 came from the factory with Group 75 AGM battery (can be upgraded to Group 78 AGM)
2004 came with a top post Group 86 AGM battery (same size as Group 75) (can be upgraded to a Group 34 AGM)
Group 78 battery is 10-1/4" L x 7-1/16" W x 7-5/16" H
Group 75/86 battery is 9-1/16" L x 7-1/16" W x 7-5/16" H
Group 34 battery is 10-1/4" L x 6-13/16" W x 7-7/8" H
Old Nov 18, 2022 | 05:46 PM
knewblewkorvette's Avatar
knewblewkorvette
34/78 fits just fine as that's the battery I use in my C5s.
Get an AGM
Old Nov 19, 2022 | 03:20 AM
jdmvette's Avatar
jdmvette
Night Owl for life
Get an AGM
@knewblewkorvette
is it worth it to get an AGM if it is rated lower than a standard flooded?
i am looking at costco for the replacement and the standard 78 battery for my 2000 is 800CCA/1000CA:
https://costco.interstatebatteries.c...636&Country=US
but the 2001 AGM 75 they sell rates at 650CCA/875CA:
https://costco.interstatebatteries.c...397&Country=US
Old Nov 19, 2022 | 09:16 AM
knewblewkorvette
Originally Posted by jdmvette
@knewblewkorvette
Definitely for piece of mind. The C5's computer is below the battery and if the battery leaks, you are looking at a major expense to repair. The AGM will not leak whereas a lead acid battery can.
Old Nov 19, 2022 | 09:48 AM
JHrinsin's Avatar
JHrinsin
I run an Autocraft (Johnson Controls) group 78 AGM battery 740 CCA 115 min 60 Ahr, that I bought at Advance Auto.
Some may insist on a 120 min rated AGM battery, so those would include, but not limited to;
Rural King (Exide) #RK-AGM78 group 78 AMG battery 770 CCA 120 min 60 Ahr
Deka/East Penn 9A78 Intimidator group 78 AGM battery 775 CCA 120 min 55 Ahr
To Battery group 78
