Help request for vacuum line connection
Old Nov 25, 2022 | 10:19 AM
TexasRedRaider's Avatar
TexasRedRaider
Default Help request for vacuum line connection
Condensed version: Had a shop do a cam install for me back in 2019 and it ran great up until the EBCM shorted and caught fire later that year.
Car sat from then until now while i spliced in a new EBCM harness and ABS pump. Anyway it miraculously started with a couple Gal's of new gas and some sea foam, but while tracing MAF sensors codes I found what looks like three unconnected vac lines the shop never hooked up. This is on the drivers side and runs just under the fuel rail. The front plumbs into the intake before the throttle body. In the rear there's a rubber elbow (middle arrow) that looks like it hooks up to a rigid line (right arrow) near the oil pressure sensor. Any idea what hooks up to the line that runs under the fuel rail (Left arrow in my pic)?
File Type: pdf
Old Nov 25, 2022 | 02:01 PM
C5Mat's Avatar
C5Mat
I think you are talking about the EVAP purge line. Should go from intake to purge solenoid, then to the line running to the back of the car. usually a test port on that line also. Looks like the 97-98 cars have a different setup than the newer stuff.
This thread may help.https://www.corvetteforum.com/forums...nnections.html
https://ls1tech.com/forums/attachmen...7&d=1501356710
Old Nov 26, 2022 | 08:06 AM
TexasRedRaider
Thank you that was helpful. The pics were gone but from the replies it seems these were either not used or don't go anywhere. Would explain why the car runs fine with them disco'd.
To Help request for vacuum line connection
