Damper pinnng question
Old Nov 28, 2022 | 02:51 PM
Fast one's Avatar
Fast one
Default Damper pinnng question
If the harmonic damper is pinned from the outside with a pin facing the center of the crankshaft, not the parallel to the shaft type pin; how is the damper removed and replaced so the pin can be placed in the same drilled holes?
Old Nov 28, 2022 | 04:08 PM
schmuckingham's Avatar
schmuckingham
I am not clear on which pin style you are asking about.
The ATI style ( it is what I used) doesnt need removed once it is in the crank and installed to the right height.
Old Nov 28, 2022 | 05:44 PM
Fast one's Avatar
Fast one
It's the ATI style and the damper has to be taken off for rebuild then put back on.
Old Nov 30, 2022 | 09:22 AM
Fast one's Avatar
Fast one
It's been a few years since the damper was installed and I forgot how it was done. I thought the pin went through the damper hub and shaft but it only goes through the shaft and the damper hub keyway slides over the extended end of the pin.
Old Dec 4, 2022 | 12:33 AM
Moved to C5 Tech.
Old Dec 5, 2022 | 11:58 AM
RonSSNova's Avatar
RonSSNova
If disassembling the engine, you will likely need to knock the pin out to get the timing chain gear off. Unless you got it perfectly aligned with that gears keyway.
When I do these during an engine build, I line the pin up with that keyway.
Anyway, just reinstall the pin prior to reinstalling the balancer.
Old Dec 8, 2022 | 07:54 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
If done properly, using the ATI pinning kit, the jig locates off the key slot that's further in, on the crank's snout. That puts the pin in line with the slots on the pulleys.
Old Dec 8, 2022 | 10:26 AM
RonSSNova's Avatar
RonSSNova
Only if you buy the right ATI kit. They make 2.
The std kit has no keyway.
918993-1 aligns with the keyway. 918993 doesn’t.
Ron
Old Dec 8, 2022 | 11:11 AM
leadfoot4's Avatar
leadfoot4
Ron
It's been several years, since I did this job, and I forgot that detail.......
Old Dec 8, 2022 | 02:26 PM
RonSSNova's Avatar
RonSSNova
Me too, and I wish I would have bought the one with a key way!
Old Dec 9, 2022 | 11:13 AM
frodo84's Avatar
frodo84
Uneducated autodidact
Can the 918993 kit be used to put the pin in line with the keyway, how does it locate the pin?
Old Dec 9, 2022 | 12:46 PM
leadfoot4's Avatar
leadfoot4
If you were REALLY careful, and somewhat lucky, in lining up the fixture, you could probably hit it right. BUT, as I recall, the real reason for using the fixture that locates off the keyway for the lower timing chain sprocket, is so it correctly "clocks" the ATI damper, which has timing marks engraved it it.
Old Dec 9, 2022 | 12:57 PM
RonSSNova's Avatar
RonSSNova
This kit is designed to be used in the car with the front cover on. I did my LS1 in the C5 this way.
Obviously you can’t align it with the keyway in this instance.
With the engine on a stand, no cover and no timing gear in place you can manually align the pin with the keyway. It’s a little tricky.
This pinning style only works for aftermarket balancers with a keyway.
Old Dec 9, 2022 | 01:33 PM
frodo84's Avatar
frodo84
Thanks, the engine is still in the car but I have everything off the front to do heads/cam/timing chain so I was thinking I could mark the crank and line it up using the ATI pin kit I have.
Old Dec 9, 2022 | 01:35 PM
frodo84's Avatar
frodo84
I thought the fluidamper didn't have to be clocked? Tell me more please....
Old Dec 9, 2022 | 04:54 PM
RonSSNova's Avatar
RonSSNova
It doesn’t, unless you want to establish TDC and add a timing pointer in order to verify timing with a timing light.
Old Dec 9, 2022 | 05:40 PM
leadfoot4's Avatar
leadfoot4
Since I was going to replace the timing chain, as well as install a timing chain damper, I had the front cover off the engine. Therefore I was able to use the pinning kit that located off the keyway.
I'm not familiar with the Fluidamper, as I installed an ATI damper......
That is correct, since the ATI damper has timing marks, therefore you need to install it in the proper orientation, so the timing marks are correctly placed.
To Damper pinnng question
Old Dec 9, 2022 | 07:00 PM
frodo84's Avatar
frodo84
Sorry, I meant ATI damper....don't know why I typed fluidamper .
Old Dec 10, 2022 | 07:58 AM
leadfoot4's Avatar
leadfoot4
That's OK, it was Friday......................
Old Oct 27, 2023 | 07:28 PM
edster75's Avatar
edster75
The -1 kit doesn't actually align the new pin with the existing key for the cam gear. It locates off of it but it's about 20 deg off. So the pin needs removed before the cam gear is removed? Seems like an f'd up way to pin the crank.
I didn't notice until I put the fixture on my crank and noticed it didn't line up. You can look at the fixture and see the keyway isn't lined up with the drill bushings.
So what does everyone do? I'm about to scribe a couple lines off the cam key and line up the drill bushing between the lines. Anyone have a better way to line these up without pulling the crank and setting it on a milling machine table. Yes I own a machine shop so the thought crossed my mind. But id mill a slot for a regular key if I went through all that trouble lol.
