Serpentine belt pully
Old Dec 6, 2022 | 11:03 AM
Cohiba's Avatar
Cohiba
Default Serpentine belt pully
I have tried searching for a few days so if I just did not search in the right place my apologies. I have some sound coming from my idler pulley/pullies. I know the one between the crank and power steering can be replaced, but is there a part number for just the pully on the tensioner instead of having to replace the belt tensioner in entirety? I wanted to change both pullies but have had no luck in finding a part for the tensioner pully.
Thanks for the assistance.
Old Dec 6, 2022 | 12:48 PM
Dads2kconvertible's Avatar
Dads2kconvertible
No, and even if there was it probably would not include a new bearing, which is the most common failure.
Old Dec 6, 2022 | 01:59 PM
Cohiba's Avatar
Cohiba
Not sure how I found it but I found a post from 7 years ago and all of these are supposed to be options to replace the pulley on the tensioner.
DORMAN Part # 419604
FOUR SEASONS Part # 45996
GATES Part # 38008
HAYDEN Part # 5996
DAYCO Part # 89015
ACDELCO Part # 1540486
Going back with GM# 12564401 for the idler.
Old Dec 6, 2022 | 03:41 PM
jjc508520's Avatar
jjc508520
Just go with the billet one
KAT-A4425 - Car Billet Belt Tensioner (katechengines.com)
Old Dec 7, 2022 | 07:29 PM
grinder11's Avatar
grinder11
If you, or anyone else, have spilled antifreeze on the belts, they'll never stop squealing. I'd try the new belts first. I have 23 years/131,000 miles on my OEM tensioners. A couple years ago, after a thermostat change (NOTE!! It's virtually impossible to NOT spill antifreeze on your belts doing the T-stat change! So now I remove both belts when changing a T-stat), even though I drained the radiator first, I buttoned up the T-stat housing, refilled the coolant, and started the car. My God, sounded like a flock of blackbirds heading South for the Winter, all under my hood!! I reasoned that there was no chirping before the stat change, so the tensioners couldn't have suddenly worn out while being parked! So I pulled the belts (A/C is a BITCH!!), and checked the tensioners. The bearings were nice and smooth, felt almost like new. When the belts came in, I installed them both (A/C was STILL a BITCH!!), and-PRESTO-No more chirping. YMMV, but I think many tensioners have been needlessly changed, when it was actually the belts themselves. I tried belt dressing, brake parts cleaner, nothing worked.....Except new belts!!!
Old Dec 18, 2022 | 09:07 AM
Joe Scafide's Avatar
Joe Scafide
Default Belt
Gates !
To Serpentine belt pully
