Heat not working
Old Dec 16, 2022 | 08:22 AM
Duhvet's Avatar
Duhvet
Default Heat not working
Does anyone have any experience the Heat not work in their 1998 C5?
Old Dec 16, 2022 | 10:57 AM
Rumplemenzz's Avatar
Rumplemenzz
When was the last time it worked?
Old Dec 16, 2022 | 11:55 AM
Duhvet's Avatar
Duhvet
Not sure, just drove it and noticed that the Blower wasn't blowing any Warm Air out.
Old Dec 16, 2022 | 03:14 PM
c5arlen's Avatar
c5arlen
Problee just you... Get the manual out.
Old Dec 16, 2022 | 04:17 PM
The Former's Avatar
The Former
Banned Scam/Spammer
Fuse #27 in the passenger side fusebox? Calling #27 in the passenger side fusebox? Pull it while car is off. Let sit for 15 seconds, put it back in. Could be a matter of blend doors, etc. Pulling and reinstalling this fuse will set those doors right. Hope this helps.
Old Dec 16, 2022 | 04:58 PM
epimetheus-lee's Avatar
epimetheus-lee
Hmmmm!
I wish that I knew you could reset the blend doors with a fuse pull earlier this year.
This summer, I got the blend door errors on DIC display with cold air AC on the drivers side and blast furnace heat on the passenger side.
Armed with the error codes, I had the dealership replace the blend doors.
(Removal and replacement of the entire dash seemed like a bridge too far for my C5 maintenance/repair skill set)
Perhaps I could have done the doors reset and saved myself a thousand !
Old Dec 16, 2022 | 05:16 PM
The Former's Avatar
The Former
Banned Scam/Spammer
Originally Posted by epimetheus-lee
Hmmmm!
Oh damn. That must have been a large bill. I got that info from this site. It's the best site for Corvettes IMO.
One other thing to try for the OP. If you spin your heat/cold **** too fast, it gets out of whack. #27 fixes this too if I remember right.
Old Dec 17, 2022 | 01:19 AM
Moved to C5 Tech.
Old Dec 17, 2022 | 10:56 AM
Justin Raney's Avatar
Justin Raney
Mine doesnt either. Does it change from hot to cold and is your ac fully charged?
I was repairing my ac system had an old ambient temp sensor that read 69 default fixed that by replacing rotten plug and sensor so it started blowing air out of all vents finally go to where i think its the hvac blend doors not switching from heat to cold. Do you have both or 4 codes for left right actuators out of range i think HVAC 363, 365?
Trying to alteast get my heater working as well as i havent wasted any freon trying to charge the ac as i still cant even get the heater to function or blend doors to swap from heat.
Old May 18, 2023 | 08:30 PM
Duhvet's Avatar
Duhvet
A/C works good just can't get Heat to blow through vents.
Old May 18, 2023 | 10:07 PM
Justin Raney
So the ac works but when switched to heater it doesn't blow hot air even with the ***** raised to red heat all the way? Maybe the actuators are stuck in one position? May i ask do you have any actuator codes or any codes at all under the instrument cluster unit for HVAC?
To Heat not working
