Headlight trouble.
Old Dec 27, 2022 | 08:50 AM
John Holt's Avatar
John Holt
5th Gear
Default Headlight trouble.
I installed new led headlight bulbs in my 2001 corvette and now the headlight doors won’t close. Also one of the new bulbs flickers. Any ideas?
Old Dec 27, 2022 | 12:07 PM
65GGvert's Avatar
65GGvert
What kind of bulbs did you install? Did you change them because the old ones didn't work? Anything unusual happen during install?
Old Dec 27, 2022 | 12:22 PM
John Holt's Avatar
John Holt
5th Gear
I replaced the stock bulbs because they were so dim I had to keep the brights on. Everything was good until I got to the last bulb. I then noticed that the bulb was flickering and the headlight doors wouldn’t close. I have ordered a canbus decoder from Walmart. Any suggestions?
Old Dec 27, 2022 | 04:08 PM
YLO Z06's Avatar
YLO Z06
2023 C5 of the Year Finalist - Modified
The LED and HID bulbs do not have enough resistance to tell the computer they are on to initiate the "close" sequence. Oftentimes, an in-line resistor is required to be installed (on the passenger side) in the headlight wiring to give a signal booster. There are several on the market. See this one from Kight Drive https://www.knightdrivetv.com/produc...or-c5-corvette
Old Dec 27, 2022 | 04:14 PM
John Holt's Avatar
John Holt
5th Gear
Thank you. I was wondering if that was an issue
Old Dec 27, 2022 | 08:26 PM
mstromquist's Avatar
mstromquist
2015 C5 of the Year Winner
Try putting the brights on and then turn the lights off. Most likely it will work. LED bulbs don't draw enough voltage to close in the dim setting. Not sure about the flickering bulb. Maybe check to make sure the connection is tight.
Old Dec 27, 2022 | 08:42 PM
John Holt's Avatar
John Holt
5th Gear
Thanks, I’ll try it.
Old Dec 28, 2022 | 04:03 AM
Moved to C5 Tech.
Old Dec 28, 2022 | 06:32 PM
grinder11's Avatar
grinder11
You might be able to wire a relay into the harness that allows all 4 lights to shine at once. It may be enough to trick the PCM into closing the doors, and it will help with illumination. I've had mine on since 2005, and it works fine......
Old Dec 28, 2022 | 07:22 PM
John Holt's Avatar
John Holt
5th Gear
Thanks, I’ll try that
To Headlight trouble.
