Headlights won’t go off or down
Old Jan 1, 2023 | 11:07 PM
Jfoste3's Avatar
Jfoste3
3rd Gear
Default Headlights won’t go off or down
Headlights stay up and running no matter what I do (twilight mode does not appear in options). Prior to this problem, my high beams would always stay on. I’m positive I have a bad multi-function switch. Anyone else have this problem? Also wanted to ask if anyone had luck with simply cleaning the multifunction switch as opposed to replacing it.
Old Jan 2, 2023 | 11:46 AM
Dads2kconvertible's Avatar
Dads2kconvertible
This thread is linked from the DIY sticky thread at the top of the forum: https://www.corvetteforum.com/forums...-replaceo.html
Old Jan 2, 2023 | 09:02 PM
DWAVette's Avatar
DWAVette
I don’t know a whole lot about the headlights yet. I am still learning my 99. But, have you checked the connection/ground to your headlight control module? I would eliminate other potential problems before tearing the column apart.
Old Jan 2, 2023 | 09:11 PM
_zebra's Avatar
_zebra
have you recently installed LED replacements?
Old Jan 5, 2023 | 03:05 PM
Burnt C6's Avatar
Burnt C6
2023 Corvette of the Year Finalist - Unmodified
2022 C5 of the Year Winner - Unmodified
Cruise-In X Veteran
St. Jude Donor '08 thru '11,'22 thru '26
the Multifunction switch has been discontinued for a while now. you can at times find used ones. I was able to pick up one a while back that came out of a 10K car that got totaled. Good luck with it
To Headlights won’t go off or down
