cold idle
Old Jan 1, 2023 | 11:59 PM
wayne100's Avatar
wayne100
Default cold idle
2004 with cam, heads cai and full exhaust. On cold start
i have to warm it up for 5 minutes or it stalls when i put it in gear
Old Jan 2, 2023 | 07:43 AM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Had this been happening after the car had been tuned or just since it’s been cold out ??…either way I’d bring the car back to your tuner because he may have screwed something up…maybe an ECT sensor since you have to warm it up…is the MIL illuminated ??
Old Jan 2, 2023 | 10:04 AM
grinder11's Avatar
grinder11
Assuming an A4 car? My A4 is similar. I have to warm coolant to 80°, then its OK. It does need a tweak on the cold start tune. Not my tuners fault, because I asked him to remove a bit of fuel at cold idle. Didn't do this before my brilliant idea!!
Old Jan 2, 2023 | 11:02 AM
wayne100's Avatar
wayne100
been happening since i got it. i got it tuned, but it still does it. no mil
Old Jan 2, 2023 | 11:04 AM
wayne100's Avatar
wayne100
yeah A4, guess I'll have to find the time to bring it back in again
Old Jan 3, 2023 | 11:16 PM
CinciZ06's Avatar
CinciZ06
You need to get it back to your tuner - it may be as simple as adding a bit of air to your base idle air flow table in the lower ECT ranges, or it could be a combination of a bunch of settings being out of whack. But, more than likely it's just needing that table adjusted. Did your tuner start with a cold motor by chance or just tune it right after you brought it to him like most do? A dude made a great setup in HPTuners, commonly referred to as the RussK file, that will log everything for your tuner and give you a pretty strong initial RAF table if he has access to your car from a cold start.
To cold idle
