Front main seal leak
Old Jan 18, 2023 | 03:17 PM
gp097's Avatar
gp097
Default Front main seal leak
Just wanted to get some opinions. I have a 2000 Vette in really nice condition. Recently my mechanic replaced the rear main seal, new McLeod clutch, cut the flywheel and installed a new slave cylinder. I brought it home and noticed a little leak was still occurring. A very minor leak. He checked it and said that the front main seal has a tiny leak also. I just paid $1,900 for the first job... would you spend another $1,100 ish to now fix the front seal and he suggested replacing the harmonic balancer also. Thoughts?? thanks.
Old Jan 18, 2023 | 04:01 PM
Vader_C5's Avatar
Vader_C5
2023 C5 of the Year Winner - Unmodified
St. Jude Donor '25
If your harmonic balancer hasn't been replaced, I would replace the balancer and front main seal as it is all part of the job cumulatively - that is how I did it last year. You can also put in a cam while it is all apart since that is also in the same area
Old Jan 19, 2023 | 01:01 AM
Moved to C5 Tech.
Old Jan 19, 2023 | 08:21 AM
redzg's Avatar
redzg
For just the minor leak? No way, no how. When the balancer goes, absolutely. But not until I see wobble or alignment shift.
Old Jan 20, 2023 | 04:45 PM
gp097's Avatar
gp097
Hello. So the mechanic is saying that the front seal is also leaking that’s why I’m still getting drips of oil on the ground. But its definitely much better than it was since he did the rear main seal. Do you think it’s worth it to spend another $1000 for the front seal?? - that amount includes replacing the harmonic balancer also.
Old Jan 20, 2023 | 09:35 PM
redzg's Avatar
redzg
There may come a point where you have to change the balancer, but from what I’ve read here it’s not a forgone conclusion. To me, I can slip a lot of cardboard under the car for a K-buck. For others, the logical answer would be to bite the bullet now.
Old Jan 20, 2023 | 09:39 PM
gp097's Avatar
gp097
And it’s not like the oil is splashing all over the place like it did before the rear main seal was replaced - it was a mess! It’s definitely a much smaller leak now. I’ve heard a lot of good things about the Lucas stop leak product. I’m thinking about putting that in the engine and seeing if it seals up this leak
Old Jan 21, 2023 | 03:16 AM
vette4fl's Avatar
vette4fl
It appears you have a fair and competent mechanic. I’d cry once and get ship shape while he’s available.
Thats a fair price. Just don’t let him use another GM balancer. Dayco PowerBond is about $100 and has great success . He should check hoses belts, tensioner, and pulleys while in there. Now’s the time when it’s apart and right in front of him.
Old Jan 21, 2023 | 03:21 AM
gp097's Avatar
gp097
Agreed. I love the car and dont plan on selling it. Thanks alot for all your help! Much appreciated.
To Front main seal leak
