Tech 2 tester question
Old Jan 21, 2023 | 02:51 PM
dales30's Avatar
dales30
5th Gear
Default Tech 2 tester question
If I take my C5 to the dealer to reset the F45, shocks inoperative, error with a Tech 2 tester will it be permanently deleted or will it return if I ever have to disconnect my battery?
Old Jan 21, 2023 | 03:00 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
The dealer may not do the F45 delete...did you change your shocks recently with non OEM ??...you disable it in the BCM and it has nothing to do with disconnecting the battery...any shop with a bi directional scan tool may do it or find someone that has a Tech 2 in your area...video below on how I did the F45 delete with my Tech 2.
Old Jan 21, 2023 | 06:06 PM
Tusc's Avatar
Tusc
Running Guns & Moonshine
Be sure to disconnect the computer dedicated to the F45 which sits in the driver side rear compartment behind a velcro piece of fabric. If reconnected after F45 delete, the car will reload F45 option and you must start over. Computer can be removed. Wire harness to the computer can be left in place simply to keep the compartment from having a hole open to the rear wheel well. Or a flat oanel can be bonded in place. I left my harness in place and just capped the sensor/shock ends while removing the sensors. I sold the computer and sensors for a few bucks to someone in need.
Old Jan 21, 2023 | 08:39 PM
dales30's Avatar
dales30
5th Gear
Thanks for a great video. Error was on the car when I bought it so I'll just assume previous owner changed shocks.
Old Jan 21, 2023 | 08:40 PM
dales30's Avatar
dales30
5th Gear
Thanks for that important info.
Old Jan 21, 2023 | 08:48 PM
C5 Diag's Avatar
C5 Diag
If you just see a "shocks inop" it's most likely not caused by non OEM shocks...you'd see the 80 MPH warning so you should scan for codes using the DIC...there is most likely a trouble code stored...let us know what it might be...it may be a C17XX DTC.
Old Jan 30, 2023 | 10:28 AM
dales30's Avatar
dales30
5th Gear
I do have the 80 mph msg. Looks like shocks have been replaced so still hunting for a shop with a Tech 2. Not having much luck.
Old Jan 30, 2023 | 03:03 PM
schmuckingham's Avatar
schmuckingham
Where are you located?
Old Jan 30, 2023 | 03:43 PM
Tusc's Avatar
Tusc
VXdiag from Amazon and a laptop will do it.
Or seek your local Corvette club and ask who might have one to borrow.
If you were near me in CT you'd be welcome to mine any time.
Old Jan 30, 2023 | 08:45 PM
dales30's Avatar
dales30
5th Gear
Bristol, TN. Waiting on some replies from a couple local shops.
To Tech 2 tester question
