Rain udders
Old Jan 23, 2023 | 04:27 PM
2010Pony's Avatar
2010Pony
Default Rain udders
Have heard talk about draining the rain udders under the hood. We’re are they and how do you drain them if needed. Thanks
Old Jan 23, 2023 | 04:46 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Old Jan 23, 2023 | 05:04 PM
2010Pony's Avatar
2010Pony
Thanks so much, didn’t know there was such a thing
Old Jan 23, 2023 | 05:21 PM
C5 Diag's Avatar
C5 Diag
Keep them clean !!...if not water may drain into the car and get the IP Fusebox and BCM wet...not good.
Old Jan 23, 2023 | 09:13 PM
RedC5's Avatar
RedC5
Wiper side - I totally ripped mine out and threw away after 2 ruined motors. 😡
Battery side I kept in. No issue I assume ok need to check them.
Old Jan 23, 2023 | 09:54 PM
T-RAY1978's Avatar
T-RAY1978
I removed all of mine, no worries, not saying anyone should, I'm sure I will get bashed here as some will say it was engineered that way for a reason, my reason for deleting them is the water can just drain through the big holes onto the ground, some will say the passenger side one will ruin the totally waterproof computer....
all said and done, mine have been off the car a while In the rain and no worries...good luck...
Old Jan 24, 2023 | 06:48 AM
redzg's Avatar
redzg
I’ve read — and tend to believe — the udders are somewhat intended to direct water flow, but more useful in keeping rodents out.
Old Jan 24, 2023 | 12:45 PM
T-RAY1978's Avatar
T-RAY1978
Rodents will not be deterred by a thin piece of rubber that is open at the bottom
Old Jan 24, 2023 | 03:31 PM
2010Pony's Avatar
2010Pony
Well I’m now a member of the clean udder club! Drivers side was very bad and nothing in the passenger side, thanks again.
Old Jan 26, 2023 | 12:14 AM
douglasjre's Avatar
douglasjre
Seems to me if we trim the lips off the output side of the udders any debris that goes in will come out the other side. Isn't that a good idea?
Old Jan 26, 2023 | 05:06 PM
mike venth's Avatar
mike venth
mike v
Veteran: Marine Corps
Also make sure that the AC utter is free and clear also. It can lead to water in the right in side dash area at/over the fuse box as well.
mike v
To Rain udders
