URGENT HELP NEEDED !!!
Old Jan 12, 2003 | 03:10 PM
20vette's Avatar
20vette
7th Gear
Default URGENT HELP NEEDED !!!
I just competed the installation of my new Kirban shifter and all seemed to go well..... until I tried to start the car. When I went to fire it up I found it would not start, my dash lights started blinking, and a strange buzzing sound came out of the radio speakers. This sound,k and the blinking dash lights stayed on for about five seconds or so after I turned off the ignition and removed the ke. The starter made a clicking sound when I tried to start the car similar to a low battery charge. I turned on the headlights and they seemed OK. I have rechecked all of the plugs I unplugged when I installed the shifter. Cany anyone give me any clue as to what I need to do to get the car running.
Thanks,
Larry
Old Jan 12, 2003 | 03:18 PM
C5-VERT's Avatar
C5-VERT
Cruise-In IV Veteran
Default Re: URGENT HELP NEEDED !!! (20vette)
Are you positive it is not the battery voltage? When you turn the key on, what does your dash volt gauge read? Taking the shifter out should not affect anything that would cause your symptoms.
Old Jan 12, 2003 | 03:36 PM
Untouchable00's Avatar
Untouchable00
Justlike he said, the shifter should not have any effect on the car starting.
Old Jan 12, 2003 | 03:54 PM
20vette's Avatar
20vette
7th Gear
Default Re: URGENT HELP NEEDED !!! (C5-VERT)
I agree simply installing the shifter should not cause my problems. The only thing I can figure is that I someway shorted the system when plugging or unplugging the traction control, asscessories or fuel filler door when removing the console.
when the ignition is turned on the instrument lights come on and the buzzint in the radio speakers starts. After a few seconds the instruments and lights turn off. When the key is removed the buzzing continues for about 10 seconds. i'm now charging the battery to see if that helps. It does seem a little low because its charging at a fairly high rate. This is the strangest thing I've seen in awhile. Any other ideas?
Larry
Old Jan 12, 2003 | 04:02 PM
XportC5's Avatar
XportC5
sounds like a nearly dead battery to me, try jumping it or charging it
Old Jan 12, 2003 | 04:03 PM
NassBlue's Avatar
NassBlue
Not to alarm you, But one day I was doing some minor interior cleaning with the radio on and when I shut off the car WHAM I had all kinds of bells and whistles going off!
I called the dealer and they knew exactly what it was BCM (body control module) The car needed to be towed back to the dealer to get fixed!
Question for you, do you have a CLB installed?
Good Luck!
Old Jan 12, 2003 | 04:05 PM
C5 StockSwap's Avatar
C5 StockSwap
Cruise-In V Veteran
St. Jude Contributor
Do you have any other wiring under your center console. Meaning custom work that you or someone else has done? I once had similar problems when I pinched a wire that I put in for my power antenna. It's a long-shot, but if everthing is stock, I can't imagine what the problem is.
Old Jan 12, 2003 | 04:24 PM
20vette's Avatar
20vette
7th Gear
Default Re: URGENT HELP NEEDED !!! (NassBlue)
NassBlue: A blown BCM sounds scary (and expensive) i sure hope thats not the problem. You'll have to educate me, whats a CLB?
C5 StockSwap: The only items under the console are the accessory plug, traction control and fuel filler door release. No add ons
Old Jan 12, 2003 | 04:51 PM
rrobert22's Avatar
rrobert22
CLB= Column lock bypass :cheers: Most likely a dead battery :)
To URGENT HELP NEEDED !!!
