Battery Charging Problem
Old Jan 12, 2003 | 03:38 PM
TRC's Avatar
TRC
Default Battery Charging Problem
After having been parked in the garage for awhile, I checked out the car to find a dead battery, which wasn't surprising. It's happened before. I connected a small (3 amp) charger to the battery, and something under the hood started clicking, which is a surprise. It is still "clicking" after two hours. What is it and should I continue charging?? :confused: :confused: Any help is appreciated!
Old Jan 12, 2003 | 04:24 PM
Patches's Avatar
Patches
Default Re: Battery Charging Problem (TRC)
What kind of charger and what kind of battery?
Old Jan 12, 2003 | 04:35 PM
wwashing's Avatar
wwashing
Disconnect the battery while you are charging it. This will eliminate the clicking so you don't have to worry about it. :cheers:
Old Jan 12, 2003 | 05:18 PM
TRC's Avatar
TRC
Default Re: Battery Charging Problem (Patches)
3 amp slow charger & OEM battery.
Old Jan 12, 2003 | 05:32 PM
Patches's Avatar
Patches
The only time I've gotten that clicking sound is when I'm connecting or disconnecting the battery posts, when the post is loosely connected. I would check to make sure the posts are properly tightened.
Also, I've hooked a charger to the battery while still connected to the car and never got that clicking.
Old Jan 12, 2003 | 07:17 PM
TRC's Avatar
TRC
Thanx, obviously I have some more checking to do. I think that this battery probably needs replacing. But I don't think that has anything to do with this unsual noise. Sounds like a clock, only faster... I haven't heard this before either. If this is a genuine problem, it will be my first with this car. It has been very reliable, great gas mileage, and good numbers at the track. Can't complain.
To Battery Charging Problem
