Disabling traction control for good
Old Jan 12, 2003 | 11:31 PM
ericdwong's Avatar
ericdwong
Default Disabling traction control for good
I did a search and didnt come up with anything. Is there anyway to disable traction control, or at least set it so that it does not turn on when you turn the car on?
Old Jan 12, 2003 | 11:34 PM
BLUTHUNDER's Avatar
BLUTHUNDER
Default Re: Disabling traction control for good (eRiCdWoNg)
Eric , I think this product is just what your looking for.
http://www.laptrax.com/
Good Luck
:cheers:
Jeff
Old Jan 12, 2003 | 11:40 PM
rrobert22's Avatar
rrobert22
Default Re: Disabling traction control for good (BLUTHUNDER)
Good Luck
:cheers:
Jeff
:iagree:
Old Jan 12, 2003 | 11:56 PM
ericdwong's Avatar
ericdwong
Hmm interesting. Also what is Competition Mode? Is this an active handing feature?
Old Jan 13, 2003 | 12:02 AM
Bill Dearborn's Avatar
Bill Dearborn
Since AH was optional on 98s you may not have it on your car. If you do it permits you to use AH while turning off traction control.
Bill
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
If you have active handling, pressing and holding down the active handling button for 5 seconds activates competitive driving mode. This shuts off traction control, but leaves active handling on.
If you don't have active handling, you obviously don't have this feature.
:cheers:
Old Jan 13, 2003 | 02:47 AM
Oskee's Avatar
Oskee
Veteran: Marine Corps
I myself would not disable TC/AH for good especially if you drive it in bad weather, even on a dry surface the rear will come out from under hard throttle during a slight turn !!!! Just my $.02 :steering: :smash: :cheers:
To Disabling traction control for good
