Worn cam?
Old Jan 12, 2003 | 11:41 PM
scool93535's Avatar
scool93535
Default Worn cam?
My 97 LS1 is rated at 345hp @ 5600 and 350 @ 4400. My last dyno runs, about 80K miles, indicate max hp @ 5700 and tq @ 4200??
Could this be an indication of a worn cam? I'm coming up on 88K miles. It runs great but idles a little rough when hot. Plugs and wires are fairly new, (less then 20K miles).
Mods are in sig. Dyno run was before adding the X-pipe and stingers.
:cheers:
Old Jan 12, 2003 | 11:42 PM
davidfarmer's Avatar
davidfarmer
Default Re: Worn cam? (scool93535)
that is typical. If you have a worn cam already, then you have some other oiling problems going on.
Old Jan 13, 2003 | 12:23 AM
Bill Dearborn's Avatar
Bill Dearborn
Default Re: Worn cam? (davidfarmer)
Those numbers do not look bad. However, you may want to think about the rev limiter being set to 6500. The HP curve on a car with bolt on mods is going to fall off some by 6500 rpm. I tried bumping it up on my car a couple of years ago since I kept hitting the 6250 rev limit when I was on the track. Once I bumped it I kept hitting the 6500 limit. Then I decided to start shifting when the tach hit 5700 and the seat of the pants acceleration was much better. Since the tach reading is slow I was probably shifting around 5900. Since then I have put the rev limiter back to 6250 and haven't been hitting it very often.
Bill
Old Jan 13, 2003 | 10:34 AM
scool93535's Avatar
scool93535
Thanks. I was thinking about shift points on the strip and was reviewing the dyno numbers. I was thinking all else being even, changing cam timing would move hp and tq numbers.
Nothing else indicates any oiling problem.
:cheers:
Old Jan 13, 2003 | 10:36 AM
scool93535's Avatar
scool93535
Default Re: Worn cam? (Bill Dearborn)
Bill
I don't have a problem bumping the rev limiter, I had it upped so I can finish the 1/4 mile with out the 3 - 4 shift. It hurts top end and ET but, improves consistancy.
Thanks for the advice.
:cheers:
To Worn cam?
