Under hood Ignition switched power source
Old Feb 10, 2023 | 01:23 PM
BmoreRnsDeep's Avatar
BmoreRnsDeep
Default Under hood Ignition switched power source
I am going to be replacing my leaking water pump with an electric pump and was wondering if anyone had a good power source for switched power under the hood, preferably in the fuse box. Is fuse #22 a good source?
Old Feb 10, 2023 | 02:28 PM
mmartinez's Avatar
mmartinez
Not knowing what current is required for the water pump, makes answering this question impossible. Hopefully someone else has already done this will respond.
Old Feb 10, 2023 | 03:41 PM
BmoreRnsDeep
Good point! I will look it up, but it is just for the relay so it shouldn't really matter right? It only triggers the relay to run the pump off of the battery.
Old Feb 10, 2023 | 08:12 PM
mmartinez's Avatar
mmartinez
I would have to see a wiring diagram, but I believe you are right, the relay also has ratings as to how much current the contacts can handle. A Google search might prove helpful.
Old Feb 11, 2023 | 09:46 AM
mmartinez's Avatar
mmartinez
Found an old thread that explains how to power the elecyric water pump. Install an external relay and power it from the fuel pump relay, then supply power from the battery to run the water pump.
To Under hood Ignition switched power source
