C5 electrical problems
Old Feb 13, 2023 | 10:28 AM
Joe_1021's Avatar
Joe_1021
Cruising
Default C5 electrical problems
I posted about this a while ago but I still have no answer.
About a month ago I decided to install my halo taillights, they worked fine for about 2 days then I decided to install the hyper flash harness, after that my headlights wouldn't go up my running lights won't work,my gauge lights won't work, my hazards work sometimes and I have no brake lights. I emailed the company that I got the tail lights from and he said that I probably forgot to disconnect the battery and blew some fuses.I forgot to disconnect my battery but I checked all the possible fuses and non of them are bad. I am leaning towards that it could be the multifunction switch(the turn signal stalk switch) but I need more help before I buy that part because it is around $350. So if anyone has any clue what it could be or think that my guess of what's wrong is right then please let me know. Thank you
Old Feb 13, 2023 | 11:00 AM
averagejoesautos's Avatar
averagejoesautos
With electrical and new parts, I always suggest reverse engineering the issue. Researching the hyper flash harness...it appears plug and play so...unplug it...return to factory configuration and bench test operation again. These cars have aging electronics and wiring so I'm always hesitant to mess with their electrics when they are working fine unless I'm re-wiring the entire car to upgrade. But for you to lose ALL of your light signals something greater then just a headlight and flasher harness install. it sounds like power to the light bus is gone (shorted feed wire? fusible link?)
My recommendation would be to do the above....test...if still nothing, get out your multimeter and see where you have power to and where you don't. If you have power nowhere...start looking at junctions and feeds for the lighting system.
Joe
Old Feb 13, 2023 | 05:59 PM
Joe_1021's Avatar
Joe_1021
Cruising
Joe
I put all the oem lights back in and also removed the hyperflash harness.I am new to electric things in cars so can you possibly give me a step by step of what to do?
Old Feb 13, 2023 | 08:01 PM
averagejoesautos
Hey Joe,
Here is where I would start (some of these steps will require researching best way to access the ports in question):
  1. Pop the fuse panel and test EVERY fuse which has to do with the lights. Fuses to the naked eye can look good, but sometimes be bad. I don't think this is your issue but we are being scientific. Test all light fuses and rule those out early.
  2. Once those are verified...hit the light switch and turn it to marker lamps. At this point...if you can easily test the light switch (which is probably a pailn in the dick in a C5 lol) see if its getting power. A much easier test would be to pop one of the marker lights and test the pigtails with a multimeter. Lights are a simple + and - circut so that should be easy enough to sort out. Stick the probes in the appropriate slots and with the lights on you will either see 12.XX v or -12.XXv if you have probes backwards. The main point here is if you see 12V...you have power to the socket...which means the light switch is good and something else is afoul (i.e. a ground issue). If you see 0.00V with the light switch on, check another light (i.e headlights). if zero there as well...the light bus is dead (or not powered). You will have to back trace it.
  3. Get the C5 of your years electrical diagram and see what specifically feeds the light bus. Typically its feed via the main fuse bus, but its important to find EXACTLY what powers it. Once you do, use the multi meter to test that junction. It will most likely be 12+ constant all the time as it feeds the fuse box, but it could be ignition keyed on but that doubtful as light need to work with the ignition off as well.
This is general information as I don't have a C5 (i got a C4) but a chevy is a chevy. The circuits are pretty simple. Basically, not disconnecting the battery and plug-n-playing could have blown a fuse, fusable link, or something which killed the power to the light circut your dealing with. A full light black out leads me to believe that its somewhere between the batt, fuse box, and light switch. A dead spot anywhere from there will lead to a total black out back (i.e. zero lights). Im suspecting the headlight switch as you say when you hit it...the motors dont energize and the lights dont flip up. But the question is...do the headlights work despite the motor not flipping them up? Try that and let me know where you get fella ; )
Joe
Old Feb 13, 2023 | 08:11 PM
Joe_1021's Avatar
Joe_1021
Cruising
Hey Joe,
Joe
Thank you,I will try that when there is a nice day here.
The lights work,high beams and low beams they just don’t pop up
To C5 electrical problems
