toe in and tire wear
Old Feb 13, 2023 | 04:25 PM
powertrain84's Avatar
powertrain84
Default toe in and tire wear
how much toe in will cause excessive tire wear? odd question, i know. doubtful many have experimented with this as it can get costly. the reason i ask is i have my car aligned for autox with a lot more camber than i want to drive on the street 1.8 degree or so, a few upper a arm shims later ive got her in "street" alignment .8 degree,but there is about 5/8 toe in gained in that change as well. im thinking this will burn the tires off pretty quickly.
Old Feb 14, 2023 | 12:14 PM
Supercharged111's Avatar
Supercharged111
Yeah that's way too much. I wouldn't do more than 1/8" max toe. What's toe with your 1.8* camber?
Old Feb 14, 2023 | 12:31 PM
lionelhutz's Avatar
lionelhutz
You'd be better off keeping the higher camber.
Old Feb 14, 2023 | 12:47 PM
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
Toe is what kills tires, not camber. Keep the camber and go 0 toe.
Old Feb 14, 2023 | 02:27 PM
powertrain84
at 1.8 camber i was right under 1/8 total out. ive got it at 1.4 camber now with just at 1/8 total toe in, seems like a lot of movement for so little change, but i did not drive it to settle it though, will have to double check it.
To toe in and tire wear
