Lubricate Door Hinges
Old Feb 23, 2023 | 09:58 PM
chevyorange's Avatar
chevyorange
Default Lubricate Door Hinges
WE just got some below freezing here in Seattle and my door squeaks!
Does anyone know the procedure and a recommendation of grease to use at the hinges?
Popular Reply
Feb 26, 2023, 11:13 AM
grinder11's Avatar
grinder11
One thing I've used with success is motorcycle chain lube. It sprays on as a thin penetrating oil like WD 40, and after several minutes coagulates into a thick grease.
Old Feb 24, 2023 | 10:12 AM
rrwirsi's Avatar
rrwirsi
I use Liquid Wrench White Lithium Grease Spray on each of the hinges using the small plastic tube applicator. I wipe off the excess.
Liquid Wrench Stens 752-914 White Lithium Grease Compatible with/Replacement L616 One Each, 10.25 oz. Size Liquid Wrench Stens 752-914 White Lithium Grease Compatible with/Replacement L616 One Each, 10.25 oz. Size
Old Feb 24, 2023 | 02:16 PM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
I recommend a marine lube that won't dry out. I lube the hinges once/year.
Old Feb 24, 2023 | 02:26 PM
Johnny Hardcore's Avatar
Johnny Hardcore
Yamalube with a small paint brush to apply.
Old Feb 24, 2023 | 02:36 PM
sayerbloke's Avatar
sayerbloke
I’ve heard that recommendation before 👍. Do you have any particular brands you’d suggest, please?
Also, has anyone ever tried WD40’s white lithium grease?
Like this one
Old Feb 24, 2023 | 05:47 PM
Johnny Hardcore
Like this one
I already suggested one of the best ones above. Yamalube is marine grease made by Yamaha.
Old Feb 24, 2023 | 06:39 PM
sayerbloke's Avatar
sayerbloke
For some reason I didn’t see that post earlier! Many thanks 👍
Old Feb 24, 2023 | 07:35 PM
Johnny Hardcore
Amazon Amazon
Old Feb 24, 2023 | 09:30 PM
Luv2spedup's Avatar
Luv2spedup
6th Gear
That's a great idea... i just ordered mine
Old Feb 24, 2023 | 10:14 PM
Johnny Hardcore
Use a cheapo paint brush from the "bottom bin" at Home Depot to apply it. Helps to put it where you want it.
Old Feb 25, 2023 | 01:58 AM
Tusc's Avatar
Tusc
Running Guns & Moonshine
Common sense. The brush idea went over my head and I had used an equine needle and some Lucas marine grease. A brush would go right on easily though.
Old Feb 26, 2023 | 11:13 AM
grinder11's Avatar
grinder11
Old Feb 27, 2023 | 07:52 PM
ztheusa's Avatar
ztheusa
Veteran: National Guard
I don't like to make a mess in there. Lemon Pledge works great and with a quick wipe down looks great too
Old Feb 27, 2023 | 10:24 PM
MSG C5's Avatar
MSG C5
Like this one
I use Lucas Oil 10320 Multi Purpose Marine Grease. You can find it on Amazon and I've also seen it at Advance Auto.
Old Feb 28, 2023 | 12:30 AM
Tusc's Avatar
Tusc
That's the stuff I use right there. It came in a triple pack.
Old Feb 28, 2023 | 07:46 AM
MSG C5's Avatar
MSG C5
Thats a lot of lube!
I think my one tube is going to outlast me.
Old Feb 28, 2023 | 09:09 AM
Prop Joe's Avatar
Prop Joe
I'm not sure how you guys get grease in the hinge bushings with a brush. I use this on many things:
https://www.triflowlubricants.com/pr...t-drip-bottle/
I use it on my planes control surface hinges, cable guides, pulleys, Bicycle chains, Corvette door hinges. Works pretty good at a penetrating oil on rusty fasteners as well. Drip bottle works the best as the aerosol puts out to much material.
Don't lose the applicator straw:
Amazon Amazon
Old Feb 28, 2023 | 03:28 PM
grinder11's Avatar
grinder11
https://www.amazon.com/Hold-Aerosol-...n%2C137&sr=1-1
Exactly why I posted about chain lube. It gets into where it has to, then turns to grease. After ensuring it has penetrated into the bushings, I'd think it's a good idea to brush on the grease, as a protective barrier.
Old Mar 6, 2023 | 11:21 PM
alblosser's Avatar
alblosser
DO NOT USE WHITE LITHIUM GREASE, it hardens up after time. Use any of the other suggestions. They will work better, longer and protect the surfaces.
To Lubricate Door Hinges
