2001 corvette. After a EBCM change years ago the telescopic wheel is not working. The seat is working ok and using the seat controls certain ways the telescopic moves . Any suggestion. I hace a 1001 code and keeps coming.
Welcome to the Forum !!…WOW your first post in 9 years !!…well to diagnose this effectively you need a “better” scan tool to look at the SCM (seat control modules) and look at some inputs to see what is happening when you activate the switches…if you have a DVOM here is the wiring for a 2001…best I can do…if you’re not good with electrical I’d take the car to an auto electric shop in your area.
Using the driver seat control I can make te telescopic work back and forth. Do no know why. It looks wiring is ok. Any other suggestion?: do the seat control (telescopic wheel) needs to handshake with ECBM trough a some king of password?
The drivers seat buttons should not control the steering wheel position, no matter what switches you press. The switch on the column interfaces with the driver seat control module. The seat control module then drives the steering wheel position motor. The seat module is also on the serial databus and can be controlled by the BCM when the memory option is active. If you have the seat memory option, then the BCM would need programing for that when it was replaced.
My car did this when I replaced the BCM before I programmed the new BCM with my option codes via a TECH 2. If you do the handshake procedure the car will start, but everything will not function properly until you program the BCM with your option codes.
As I recall I also had an airbag light prior to programming the BCM.
there is two connectors beneath the drivers seat. Check that they are not plugged in tightly. One of those connectors controls the telescope. If they are plugged in correctly check for any loose wires. I had this exact problem.
