LPE TT Dyno # from Norway
a year ago i bought a silver 1997 TT from SW, took it to Norway and due to duty system in Norway, i converted all TT stuff to my 1998 Coupe.
Sold the silver car to a good friend.
Before i took it over i had it dynoed (MTI), it had 488 rwhp uncorrcted and 453 rwtq.
When i swapped it over to my car, i bought LPE stage II heads and their GT2 cam, LS6 intake.
And i used LS1Edit to tune it, with a little help from nospam.
A week ago, we installed a new Dynojet 248 in my friends "farm house" and last night i dynoed my TT.
First dyno pull showed 450rwhp and 476rwtq (corrected, DIN) ??? wtf.....
Then we attached A/F sensor and now i see my problem, my A/F ratio is
11:1 from 3400 rpm (where i start, i have auto) and drop below 10:1 all the way to redline 6700 rpm. (it will not show any lower than 10:1)
We increased boost from 5 psi to 8 psi, and now i got
515 rwhp and 547rwtq, A/F ratio a little better, but still below 11:1 all the way to redline.
This run i had a passenger to keep an eye on my boost gauge during dyno pull.
He said boost dropped as i was getting close to redline, it dropped from 8 psi to 6 psi, so it seems that LPE stage 1+ turbo is not capable of flowing any more, does this make sense ?
Anyone know how much HP/TQ will increase if i get a correct A/F 12.8:1 ?
Boost, i will be aiming for 8 psi street and 10 psi drag racing.
SlowC5, i still have my cats in place, they will also be removed before spring :-)
Then tune it on a dyno, aiming for the suggested 12.3:1 and see where that leaves me.
SlowC5, you still have your car ?
Any good hint regarding tuning fule curve under boost ?
TIA
