Forged LS2 swap
Here is my build list:
A&A V3 Ti with 3.6" pulley
80# Deka injectors
52mm Turbosmart BOV
NGK TR6 plugs
2 bar MAP sensor
IAT sensor spliced post MAF
A&A external dual fuel pump with return
Turbosmart FPR2000 - static
Alky meth injection
Tick stage 2 blower cam (227/243, .625"/.615', LSA 116+6)
Straub trunion kit
Tick hardened pushrods (7.375")
Tick .660" dual valve spring kit
Stock lifters
Stock heads
Stock bottom end
ATI stock sized balancer - pinned
ARP crank bolt
Katech C5R timing chain
C6 PS pulley
Melling 10295 high pressure oil pump (red spring / black o-ring)
Dewitts cut down radiator / cradle at stock height
SPAL fans
Stock thermostat
LG pro long tubes 1 7/8" with catless x
Borla stingers
ECS diff brace
Mantic twin disc ceramic with lightened steel flywheel
Hurst short shifter
Antivenom mod
New TOB
New stock slave cylinder
AEM wideband
Autometer boost gauge
Air pump delete / exhaust block off
EVAP delete from driver's intake manifold
Vibrant vacuum block to T fitting in brake booster
(2 lines to external fuel pump hobbs at 4 psi / 7 psi, 1 line to BOV, 1 to boost gauge, 1 to alky meth kit)
New fluids (diff / trans / oil / clutch / PS)
New intake manifold gaskets
New valve cover gaskets
New water pump gasket
New front timing cover gasket
New rear main seal
Here is a link to the build:
https://www.corvetteforum.com/forums...ispreloading=1
I have considered several options including just sending the LS6 block for a forged rotating assembly, but thought the added cubic inches would be a plus since I'm pulling the motor. Based on some searches, I think the LS2 would be the way to go. I do not want to replace a bunch of items that I recently bought and would hope they transfer over to the new block.
Can I reuse my stock LS6 243 heads and intake manifold on the LS2? Would my LG long tubes fit clearance wise with the new block? Also does the LS1/6 ATI balancer fit the LS2 crank?
What compression should I aim for with 13-14 psi?
Finally, could you tell me what modifications would be required to make this motor fit (tap for knock sensors, relocate cam position sensor, new cam cover, grind bracket near the engine mount, etc...)? I would plan to buy everything new with a 24x reluctor wheel and not run a Lingenfelter box.
Thanks!
Also I’ve heard using the LS6 top end on the LS3 block will create higher compression and isn’t ideal whereas the LS2s used the 243 heads.
Is there anything that needs to be changed in terms of the 2004 PCM with either of these motors other than the usual tune after swapping?
